Door Speaker Problems
tee17
Copper - Posts: 93
Posted: March 31, 2006 at 7:38 AM / IP Logged
I have a 2000 Intrepid. I just installed some 3 way 6 1/2 in my doors. the problem is that when i turn the volume on the radio up. I get static out of the speakers once i get the volume past 30. Does anyone know what may cause this.
coppellstereo
Silver - Posts: 785
Posted: March 31, 2006 at 9:14 AM / IP Logged
how much power do they handle, and how much are you giving them?
tee17
Copper - Posts: 93
Posted: March 31, 2006 at 9:49 AM / IP Logged
they handle 240 watts. the radio is only 200 watts
xtremej
Gold - Posts: 1,440
Posted: March 31, 2006 at 12:48 PM / IP Logged
I think  you should look for what the power is rms/continous. What knid of head unit and speakers
forbidden
Platinum - Posts: 5,354
Posted: March 31, 2006 at 1:07 PM / IP Logged
What you are doing here is simple. Throw out the wattage claims that you stated above. They will make power like that if they get struck by lightning and then are put on life support. Your deck is going to struggle to make 15w x 4 of clean power. Your speaker will only reproduce what you give it. You give it clean power, it makes clean sound. You feed it distorition, it produces distortion. The root cause of the problem is that the tiny little amp in your cd player has run out of clean power and is producing distortion that your speakers will faithfully reproduce until they die a horrible smelly, sometimes smoky death. Turn down the volume control. Want it louder and clean, add a amplifier that produces 35 - 50w rms x 2.
xtremej
Gold - Posts: 1,440
Posted: March 31, 2006 at 1:36 PM / IP Logged
Just like he said.Door Speaker Problems - Last Post -- posted image.
godblessdremil
Silver - Posts: 273
Posted: March 31, 2006 at 2:00 PM / IP Logged
In other words you need an amplifier.
