2001 Nissan Sentra hazard light plug
esmith69
Gold - Posts: 1,511
Posted: April 03, 2006 at 2:53 PM / IP Logged
Anyone know the pinout for this?  My friend just had her car broken in to and they yanked (literally) the whole console thing out.  Instead of just unplugging the hazard light plug, they pulled the thing so hard that the wires came out of the white plastic plug. I still have the white plastic part and each wire can still go back into the plug ok and seems to be fairly sturdy, so I don't need to know what each wire does.
I just need to know where each color wire goes in the white plug.  Any ideas/advice?  Her car is basically not drivable right now because she can't use her turn signals, so any help you guys could give me would be much appreciated.  Even if you don't have an '01, if you have access to the white hazard plug on another nissan of similar vintage, that might help.
Thanks!
Ethan
Donate to the12volt.com
Big Dog
Gold - Posts: 1,265
Posted: April 04, 2006 at 11:33 AM / IP Logged
click the link sentrahazard.pdf
Prepare your future. It wasn't the lack of stones that killed the stone age.
esmith69
Gold - Posts: 1,511
Posted: April 04, 2006 at 11:38 AM / IP Logged
thanks dude, you rock!  Now if I can just remember how to read a wiring schematic...;)
Ethan
esmith69
Gold - Posts: 1,511
Posted: April 05, 2006 at 9:53 AM / IP Logged
Thanks again for that PDF file.  Unfortunately, the diagram is pretty tough to decipher.  I'm gradually getting there, sort of trial and error, but it's really tough as I'm going pretty much blindly.  I did figure out which pins are controlled by the switch.  It looks like only two are.  All of the other wires just happen to interconnect inside the plug.  Stupid design!
Really what I need is a photo of a plug, (or a description of the order in which the wires go in the connector as I don't think it matches up with that schematic).
Ethan
Big Dog
Gold - Posts: 1,265
Posted: April 05, 2006 at 10:23 AM / IP Logged
Most Molex connectors have the numbers molded into the plastic (sometimes you need good eyes). Logic dictates that the #1 would be at one of the two extremeties. It's possible that they didn't write all the numbers but just a simple "1" if you look closely.
Worst case scenario: you'd have to go to a local scrap yard and get the plug and match 'em up.
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
