Upgrading Alt?
shott8283
Copper - Posts: 112
Posted: April 04, 2006 at 1:10 PM / IP Logged
hey fellas,
quick question that i want to address before i upgrade my alt.  currently on my 2001 dodge ram i have a 136 amp alt.  i am wanting to upgrade b/c of the electrical demands that i am adding onto the original alt are starting to climb ie: elec fans, system, aux lighting, carputer etc etc
what i am wondering is, with my voltage regulator being built into my PCM/ECM computer, how large could i go with the alt upgrade?  currently i have 2 options, 1 being a standard 170 amp upgrade for an oem fit,  or i could use a 205 amp desiel alt .  witch im still unsure of b/c of the fact that its a desiel alt and im not sure if the current output is correct for my gasser truck.
any ideas would be great or any places i could go to find out this information
thanks in advanced
geepherder
Platinum - Posts: 3,668
Posted: April 04, 2006 at 7:08 PM / IP Logged
Go as big as you like.  The voltage regulator does just that- regulate voltage, so just putting in a higher output alternator will not hurt it.  The alt will only put out the amount of current that is needed.
