Need Tundra 03 installation info
inkjetcollector
Posted: January 02, 2003 at 10:00 PM / IP Logged
Please help if you can.  I have not worked on car installs since college days.  Just purchased a new 03 Tundra and am trying to remove the head unit.  I removed the screws in the air vents and cannot tell where to go from there.
Thanks in advance.
Dave
weston_skye
Posted: January 03, 2003 at 7:35 PM / IP Logged
I have a 2002 tundra and on mine I had to unscrew the ash tray and then just pull the middle dash part out.  It may be different for the 2003 model.
If you are installing an aftermarket cd player, I have a question for you, also.  I put one in mine but the only problem is that they don't make a wiring harness for it yet, and I dont know what stock wire colors correspond to the standard colors of a new cd deck.  If you happen to know which ones go with each other, I bet the 2003 and 2002 are the same.  If not, thats ok too im just having a hard time finding out Need Tundra 03 installation info - Last Post -- posted image.
Good luck with the head unit
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
