'04 buick rendevous 555gw
xtremej
Gold - Posts: 1,440
Posted: April 10, 2006 at 12:34 PM / IP Logged
I am using a 555gw to bypass passkeyIII on this buick. I have tested with the key in the ignition starts fine. I have column cover removed and I am ready to tie in this bypass. I've found pink wire off passkey cylinder 2 purples and the green keysense wire. It says to cut the pink and wire it inline with pink and pink black.  Purple goes to which 1 of the 2 purple wires I found, how I am supposed to know which one. If its a data wire its not testable? keysense is done.  Please bare with me I generally don't use these I bought out a competitors inventory. Any advice would be awesome.....
xtremej
Gold - Posts: 1,440
Posted: April 10, 2006 at 12:55 PM / IP Logged
I'll answer my own question. Its the purple in the rear of the plug last purple. '04 buick rendevous 555gw - Last Post -- posted image.
xtremej
Gold - Posts: 1,440
Posted: April 10, 2006 at 1:18 PM / IP Logged
I may have spoke to soon. I noticed while testing the security light in the gauge cluster is illuminated. Anybody have any ideas? It starts and runs fine. Anybody???
NowYaKnow
Gold - Posts: 1,217
Posted: April 10, 2006 at 7:04 PM / IP Logged
Did you power up the brown second accessory? If not, it will throw the security light.
Also just FYI it shouldn't matter which purple wire you tie into. If you follow them down to a plug, you will see one dead ends.
Mike
xtremej
Gold - Posts: 1,440
Posted: April 10, 2006 at 7:12 PM / IP Logged
I did I just remebered I forgot to program it as an accesory, its programmed as an ignition. I don't like to rush, the dealer must have called 10 times crying about getting the car back. I don't think 3 hours is too long, maybe I'm just slow. Thanx for the info, any idea if it will damage anything it may take a couple of days to get it back?
