Picking out amps
jdiablo
Member - Posts: 25
Posted: April 16, 2006 at 6:24 PM / IP Logged
I'm planning on running three Rockford Fosgate Stage 2 dual 4 OHM subs.
I had the Phoneix Gold PD 396 1600 watt 4 channel amp,and ONE RFS 12 inch sub.It thumped pretty good in my focus until i got into a car accident.I am now picking up a 03' Mercury Mountaineer so I want to go big or go home.
My question is i want the most power out of each sub as i can get from each amp,that is the thing im stuck on,im fairly new to all of this,I understand some of it,i just dont get that with a dual 4 ohm sub i checked the wiring options and it says that i need a 2ohm stable mono amp,so what would be the best amp to push my subs to the max,the max RMS on the subs is 1000 watts.
Thanks for any help,I will be on here alot in the upcoming months considering I am going all out on my mountaineer,thanks!
jdiablo
Member - Posts: 25
Posted: April 16, 2006 at 6:45 PM / IP Logged
Some of the parts and what not I will be using.
Picking out amps - Last Post -- posted image.
The box
sprawl85
Copper - Posts: 204
Posted: April 16, 2006 at 6:51 PM / IP Logged
purdy
fiberglass reminds me of peanut brittle... but fiberglass tastes better!
jdiablo
Member - Posts: 25
Posted: April 16, 2006 at 7:09 PM / IP Logged
This is the amp I am looking at,well three of them to be exact.... Power Acoustik A1000DB Subwoofer Mono Amp
450W Class D • 800 Watts @ 2 Ohms • Remote Level Control
forbidden
Platinum - Posts: 5,354
Posted: April 16, 2006 at 7:48 PM / IP Logged
Asking for problems there dude. To properly tune 3 amps of different efficiencies to drive 3 subs in one vehicle and then balance the bottom end to the front speakers, well, if you pull it off, good for you. Next up is the space that 3 amps take up, 3 sets of wiring + distro blocks, more current pulled from the electical system, to me this is just adding up to nightmares for you. To go with such a high end sub as the Power T2 and then throw a flea market amp on them, well, I would be reconsidering your amplifier options.
forbidden
Posted: April 16, 2006 at 7:52 PM / IP Logged
Yikes again, 3 subs in the same box......even harder to tune the system properly. If you want those subs to wail and I mean part your hair, do not use a basic but cool looking box. Get a proper box made for the capabilities of these sub, especially if you are wanting to go all out. Read these stickies.
https://www.the12volt.com/installbay/forum_posts.asp?tid=74592&PN=1
https://www.the12volt.com/installbay/forum_posts.asp?tid=74519&PN=1
jdiablo
Member - Posts: 25
Posted: April 16, 2006 at 8:59 PM / IP Logged
Ok so more or less you are saying is i should make a box,or get one custom made for me.I will most likely go with my second option just because I never made one yet.
It seems that you know alot about systems,what amp would you reccomend for me...either one amp or three,thanks for helping out
jdiablo
Member - Posts: 25
Posted: April 16, 2006 at 9:05 PM / IP Logged
This amp looks a little more up to par with the subs
JBL Power BPX2200.1
boardinbum
Silver - Posts: 358
Posted: April 17, 2006 at 12:32 AM / IP Logged
Man, that is going to be ALOT of power!
~3,000 RMS for a daily driver?! I hope you have some daily ear plugs to use with those...
Anyway, listen to Forbidden - he does know a thing or two...
And don't forget, there's no way you're going to be able to pull something like this off with your vehicle's stock electrical system.
jdiablo
Member - Posts: 25
Posted: April 17, 2006 at 7:38 PM / IP Logged
What would I have to do for it to handle it?Probably get the stator re wound up for some higher amps and what not correct?
