Dual Subwoofer Wiring
bassreka
Member - Posts: 11
Posted: April 18, 2006 at 7:16 AM / IP Logged
I have (2) 8" 300rms 600max 4ohm speakers wired to a 2/1 channel amp, 165w x 2(4Ohms) 500w x 2(2Ohms). Whats the best way to connect them (in detail)? Or do i need a different amp?
haemphyst
Platinum - Posts: 5,059
Posted: April 18, 2006 at 9:21 AM / IP Logged
How do you have them connected right now? Is it working? Why do you feel it is incorrectly connected?
With your present gear, one woofer to each channel of the amp (leave the amp in stereo mode), presenting a 4 ohm load. Your woofers will receive 165 watts each. This is your only SAFE option. (and I'm gonna get called on that statement...)
stevdart
Platinum - Posts: 5,816
Posted: April 18, 2006 at 9:48 AM / IP Logged
If you are using these to provide some of the midbass as well as sub bass, then the way described above is the best.  You will have stereo.  If you are crossing these over at 100 Hz or below, though, my preference would be to wire the subs in series to 8 ohms and bridge the load across the channels.  The output is still 165 watts per sub.  You have seen the woofer wiring wizard located in the help section along the left column?
By the way, there is a misprint in the power data you provided for that amp.  500 watts X 2 at 2 ohms??
Platinum - Posts: 12,488
Posted: April 18, 2006 at 10:17 AM / IP Logged
Are these subs DVC or SVC ? Go here and type in your configuration for woofer wiring.
Posted: April 18, 2006 at 10:19 AM / IP Logged
Depending on it he has a DVC or SVC he can wire it up in either 2 ohm ( SVC ) or 4 ohm ( DVC ). IMO, either of these are safe.
