reversed door open/stereo off relay
zildjianx
Posted: April 19, 2006 at 7:51 AM / IP Logged
when my door opens my stereo will stay on but when i close it the stereo goes off.. how do i reverse the trigger? my door trigger stops making ground. so how would i reverse that signal without making another door trigger (actually drilling and making a new trigger itself)?
Grady
1989 cabriolet
dstang24
Copper - Posts: 98
Posted: April 19, 2006 at 10:15 AM / IP Logged
Use a Relay... Search the12volt.com for relays.  Here's a link...
Convert a Negative Output to a Positive Output
If you have a switch or an alarm or keyless entry that has a negative output that you wish to use to switch a device that requires 12V+ such as a horn, dome light, parking lights, head lights, hatch release, etc., wire a relay as shown below to convert the negative output (trigger) to a positive output.
https://www.the12volt.com/relays/page1.asp
reversed door open/stereo off relay - Last Post -- posted image.
Here's the same configuration showing a negative output from an alarm or remote keyless entry used to activate a trunk release solenoid that requires 12V+ to release the trunk.
Team Edge Audio
