voltage regulator
eljay8619
Member - Posts: 16
Posted: April 20, 2006 at 10:44 AM / IP Logged
can anyone explain what this is to me? i bought a 130 amp alt and the guy who i bought it from was explainin it to me said that it has a voltage regulator in it....he said it tells the alt when to kick in with 130 amps? can anyone clear this up for me
haemphyst
Platinum - Posts: 5,059
Posted: April 20, 2006 at 10:54 AM / IP Logged
No, a voltage regulator does just what the name says it does - regulates voltage. It does this by monitoring the output voltage of the alternator, and adjusting the power fed to the excitor field, by increasing or reducing the voltage fed to the excitor. It can also turn off the excitor field, if there happens to be an overvoltage situation, or if the battery is fully charged.
It has nothing to do with "telling the alternator where to kick in". An alternator will ALWAYS make power, but if the regulator dies, there is no field in the excitor, so no output. I have also seen, on the reverse side, regulators "stick" and they allow the alternator to "run away", overvolting the system and frying other very expensive components in the car... I think this is a fairly rare situation today, though...
An alternator can only make a certain amount of current, and the amount of current produced cannot exceed it's design capabilities. it is perfectly capable of making only one amp, and it can do that forever, but your alternator cannot make MORE than 130A and still be able to maintain 14.4 volts. And if you pull more than 130A from it, it will likely fail in very short order.
eljay8619
Member - Posts: 16
Posted: April 20, 2006 at 11:05 AM / IP Logged
aight thanx for the info
