Transpounder By-Pass
hitec
Member - Posts: 25
Posted: April 21, 2006 at 10:47 PM / IP Logged
I bought a Prostart to install in my 2000 winstar van. I know how to install a remote starter but I am having problems to bypass the transpounder systems. Can you give me any advice? Which wire should I connect to the bypass kit from the remote starter?Transpounder By-Pass - Last Post -- posted image. Transpounder By-Pass - Last Post -- posted image.
auex
Platinum - Posts: 5,041
Posted: April 21, 2006 at 10:49 PM / IP Logged
You need to connect the bypass to a status output so that the bypass knows when you are remote starting. What bypass are you using?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
hitec
Member - Posts: 25
Posted: April 21, 2006 at 11:12 PM / IP Logged
Bulldog.
TY!
auex
Posted: April 21, 2006 at 11:14 PM / IP Logged
Does it have a box you put a key into or does it have a pellet that you place near the key cylinder?
hitec
Member - Posts: 25
Posted: April 21, 2006 at 11:23 PM / IP Logged
With extra key to place inside the box.
auex
Posted: April 21, 2006 at 11:32 PM / IP Logged
OK, on your alarm there should be an output labeled (-)out when running(I assume this is the alarm) . I assume that this is your bypass. I would try hooking the wire mention above to the blue wire of the bypass. You should only have power(red), ground(orange), the trigger(blue) hooked up. Then do five loopes around the key cylinder and plug it in.
hitec
Member - Posts: 25
Posted: April 22, 2006 at 12:07 AM / IP Logged
Thanks for your time and the knowledge you have .AUEX !
john ogrady
Copper - Posts: 82
Posted: April 23, 2006 at 9:20 PM / IP Logged
What alot of people are doing when they use this type of by-pass is to grind the key a bit you are using.So it cannot be used in the ignition tumbler for security reasons.
t0mmyr
Copper - Posts: 55
Posted: April 25, 2006 at 2:48 AM / IP Logged
i love my viper and universal dei bypass, i have a chipped key inside, uncut :) so if someone manages to find my alarm and key box hidden behind a riveted area to get the key out, they wont be able to unlock the car or turn the ignitton
