strobe systems
12voltnewbie
Posted: April 28, 2006 at 3:36 PM / IP Logged
i have a showcar..want to add some strobes to it..i want to mount strobes behind grills on my body kit..basically 2 strobes up front and 2 in the rear...i know whelen has a hide away strobe kit but can I use those for outdoor use?will there be moisture issues etc?what strobes can I get for out door use..I need small dimensions if possible...I know whelen has good hiseaway kits and nov does too..what should I be looking for?i have seen new LED self contained strobes..but are they are bright as srobe bulbs?do they last longer?will i still get that bright glow that makes a persons retina take a few seconds to adjust..hahaha this is for a demo car..thanks for all the help in advance..
jantman
Member - Posts: 9
Posted: May 09, 2006 at 8:00 PM / IP Logged
I know it's been a while since you posted this...have you gotten an answer yet?
Whelen's Hide-A-Way strobes are meant to be put in the headlights/turn signals. You can buy rectangular lightheads that are intended to go behind the grill, and get them with white lenses if you want. I'd suggest against putting the hide-a-way strobe heads just mounted behind the grill.
copcarguy
Copper - Posts: 122
Posted: May 18, 2006 at 9:16 PM / IP Logged
Better to look @ Whelen's TIR3 LED lights. Brighter head on than strobes and less install headache. No power supply needed and they have built in flashers so just get 12 volts to them and away you go! Have fun.
R Jackson
Owner/Installer
TRM Emergency Vehicles
Information is advice only and should be confirmed with OEM or quality test equipment.
Boyertown, Pennsylvania
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
