02 Toyota Sequoia replace oem stereo
ewinkley
Member - Posts: 10
Posted: May 03, 2006 at 4:43 PM / IP Logged
I have an 02 Sequoia and would like to replace the stock stereo with a Blaupunkt, as the Blaupunkt has the ISO connectors needed for my bluetooth handsfree phone kit that routes sound through the front speakers of the stereo.
I can only find one connector on the bottom of the EQ / whatever it is that is directly behind the stereo and a little lower - the connector from this to the stereo is not one i recognize.  does anyone know how to replace the stock stereo in this vehicle?  What cables do i need?  Thanks.
snoracer98
Member - Posts: 15
Posted: May 03, 2006 at 4:53 PM / IP Logged
i dont konw about your install question, but pioneer is coming out with the 9800bt witch is a bluetooth headunit, its supposed to be out this month and actually holds your phonebook and displays caller id on the screen... might be another option for you, i know as soon as its out i will have one in my truck, that way you wont have to buy iteams to connect to it.. just the radio.
godblessdremil
Silver - Posts: 273
Posted: May 03, 2006 at 7:15 PM / IP Logged
Do you mean the connector is not like the blankpunkt connecter. It never will, you need an after market harness(or interface if you have a boise or infinity system) that plugs in. And as far as i know the radio is upfront and not loacated somewhere else so all the wires should be there.
