Command Start
majorj13
Member - Posts: 12
Posted: January 06, 2003 at 10:07 AM / IP Logged
I have a CS 290i-c That I installed last week and starts the car great thanks to Jeff, But I can not get the locks to work, I found the correct wires and I have spliced into the door panel right at the switch, So I know I have the right wire, When I bush the CS button all that happens is the lights flash. The Car I installed it on is a 1992 Oldsmobile Cutlass Cierra, I was wondering if the locks not working had something to do with the car having automatic locks? When the car is put into gear the doors lock. Any help would be greatly appreciated.
Thanks in advance
Player69
Silver - Posts: 504
Posted: January 06, 2003 at 11:41 AM / IP Logged
There is a door lock relay on the passenger side kick panel.  There will be a black and a blue wire one at each end of this relay.  Blue is lock Black is unlock.  Your Command start has a reversing polarity door lock outputs.  You should be able to connect the wires directly to these two wires and it should work.
majorj13
Member - Posts: 12
Posted: January 06, 2003 at 11:45 AM / IP Logged
Thanks I 'll give it a try, and let ya know
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
