remote start
madmatt
Posted: January 06, 2003 at 9:00 PM / IP Logged
I am installing a avistart remote start and keyless entry in a 96 Pontiac Grand Am.  Dose anyone have a wiring diagram on which wires to connect to?  Could realy use the help, thank you.
Moderator - Posts: 12,488
Posted: January 06, 2003 at 11:32 PM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|blue                |+  |drivers kick panel          |
|     POWER UNLOCK|white               |+  |drivers kick panel          |
| PARKING LIGHTS +|brown               |   |steering col. switch        |
|       HEADLIGHTS|yellow              |+  |steering column switch      |
|     DOOR TRIGGER|grn/blk, lt.blue *2 |-  |drivers kick-pass kick      |
|  TRUNK/HATCH PIN|ORANGE / black        |-  |at light in trunk           |
|       TACHOMETER|*1                  |   |                            |
|      SPEED SENSE|dk. GREEN / WHITE     |   |at chime module             |
|       BRAKE WIRE|lt blue             |+  |at brake switch             |
|     HORN TRIGGER|black               |-  |steering column switch      |
|           WIPERS|purple              |+  |steering column switch      |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |LF window motor in door     |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |drivers kick panel          |
|  LR WINDOW UP/DN|dk. green - purple  |A  |drivers kick panel          |
|  RR WINDOW UP/DN|lt. green - purple  |A  |drivers kick panel          |
Notes:
NOTE:  This vehicle has the passlock immobilizer system. Use DEI part number 555t or 555L when adding a remote starter system.  *1 The V6 tach is PURPLE / white at the coil pack on the top rear of the motor.  The 4 cylinder tach wire is white in a 16 pin plug on the top right side of the motor.  *2  You must diode isolate these wires.
Monday, December 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
