2006 Toyota Matrix doorpin
forbidden
Platinum - Posts: 5,353
Posted: May 20, 2006 at 5:36 PM / IP Logged
This car must have that new invisared wire for the doorpin. Everything I have says a red wire, pin4 on the 10 pin harness a the underdash fuse panel. Well, it is fricken invisable or I am blind. Anyone had this car yet that can shed some light please?
mo12v
Posted: May 20, 2006 at 8:59 PM / IP Logged
Last one I did the wire was
RED / White @ Interior Light Switch on Dash
the Interior Light is RED / Black same place
Negative Pulse
MO
forbidden
Posted: May 20, 2006 at 9:42 PM / IP Logged
Nothing doing there, that was the second place I checked. That wire is non-existent. As this is a manual transmission vehicle and a alarm / remote start, it is highly imperative that I find the proper wire and not take shortcuts.
forbidden
Posted: May 21, 2006 at 1:38 AM / IP Logged
So, after getting right wized off, it looks like the wire is red / black. It is found coming out of the top of the underdash fuse box on the drivers side, lower dash. Remove the fold down storage pocket for access. Molex should be the first one on the top left.
Chris Luongo
Platinum - Posts: 3,746
Posted: May 21, 2006 at 1:46 PM / IP Logged
The easiest wire, which is NOT affected by the car's domelight delay, is RED / yellow, in the harness that runs along the driver's doorsill.
It catches all four doors, but I cannot remember if it catches the rear hatch, or rear hatch glass.
techfiftyfive
Copper - Posts: 46
Posted: July 23, 2006 at 7:11 AM / IP Logged
It catch's it ;)
KarTuneMan
Platinum - Posts: 7,056
Posted: July 25, 2006 at 12:22 AM / IP Logged
How about the red @ the cluster....? NEG(-) 2 wires down from the black tach wire!
Monday, July 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
