MECP Testing?
xtremej
Gold - Posts: 1,440
Posted: May 23, 2006 at 10:45 AM / IP Logged
The test itself is easy also.
supradude
Silver - Posts: 915
Posted: May 23, 2006 at 11:13 AM / IP Logged
Don't they have a "practice" test online?
'85 Toy
silentblackhat
Copper - Posts: 138
tnecius
Member - Posts: 8
Posted: July 23, 2006 at 3:45 PM / IP Logged
Just like anything else, MECP is a place to start for the basics. The installers w/out MECP had to start somewhere also..... which means they had to be taken under someones wing in there early stages.
Almost any career field you look at, Installing, Police, Fire, Attorney, Cook, Doctor, or whatever it may be has a starting point. Some required schooling (Degrees - in which after receiving one you do jump right in to whatever it is. There is a learning curve). Some Don't require schooling; Although, there are many schools out there to teach the specific craft. Some are just OJT.
At any rate, it just depends on each individual person weather they want to excel, or, its just something to do in the mean time to hold me over (hobby).
Just my .02
Platinum - Posts: 12,488
Posted: July 23, 2006 at 5:41 PM / IP Logged
It started as a hobby for me and it's now my full time job and business. If you want to take the MECP test adn see how you do, by all means do it as it will give you a better understanding of the theory behind the industry but don't think that this will make you ready for the real deal. No harm in doing the test though......
Melted Fabric
Silver - Posts: 509
Posted: July 24, 2006 at 2:47 PM / IP Logged
I usually just figure out a way to take it apart, but end up bending or breaking clips sometimes. Good thing I am not running a shop with actual clients.
I wanted to attend Mobile Dynamics to "fill in the blanks."
MECP is cool for knowing the "technical" things, but hands-on, I would say, get hands on.
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
silentblackhat
Copper - Posts: 138
Posted: July 25, 2006 at 9:49 PM / IP Logged
nouseforaname wrote:
i don't need that paper hanging on the wall to make myself feel better, but i do need it to make my check a little bigger.MECP Testing? - Page 2 - Last Post -- posted image.
i know EXACTLY what u mean.  i know i dont need any of those certificates because i have a lot of hands on experience and i know how to do everything correctly.  with this i can get a higher up position in a place i am applying for so thats y im getting it also.  i cant believe how little knowledge people have that install stuff at a place i went to.  i even talked to the MANAGER and he didnt how how to correctly wire up speakers. he kept telling me i was wrong(hooking 2 8ohm subs in parallel makes a 4 ohm load on the amp, the manager kept explaining to me that its a 16 ohm load in parallel...MECP Testing? - Page 2 - Last Post -- posted image....kinda dumb).
silentblackhat
Copper - Posts: 138
Posted: July 26, 2006 at 7:32 PM / IP Logged
it was so ridiculous when i went there. i had 2 blown subs with a warranty on them still.  so i exchanged them for some new infinity subs that were dual voice voils(4 ohm per voice coil).  my amp puts out 500 watts rms at 4 ohms.  the subs can handle 250rms each max.  I wire it up so the subs are 8 ohms each and run them in parallel so it puts the 4 ohm load on the amp, also putting 250watts to each sub.  The manager tries to explain to me how my amp is incompatable with the subs that i am getting.  umm, no? its perfect for the sub setup. this was the highest ranked car audio person in the store, not just on that shift but the whole store. then i went back a few months after that asking for a power line filter for an amp THAT I MADE MYSELF(like went to radio shack, got the resistors and everything and build it myself).  He was trying to explain to me that the only filters there are are groundloop isolators.  well first of all i know thats wrong and 2nd of all, if i build my own amp, i THINK i know a little more what i need for it. he was explaining that the noise isnt comming from the power line, its comming from the RCA conection since its a ground loop.  well first of all, the microphone preamp that i made for my PA system isnt conencted to any other amp, its self powered and i had a speaker conencted to it to test it out...there was NO groundloop what so ever.  the next day i go to an actuall car audio shop and they knew exactly what i needed(the power line filter), and got it for me, i was in and out within 2 minutes.
Oh yeah one last thing.  Someone i know that is in the senior position there(one step below a manager) that sells car audio and has for over 2 years (at that SAME store) tried to explain to me that when the number has a K after it, it means the sound is getting lower in frequency....so by his saying, a 463hz sound is WAY higher than a 20khz sound wave....hmm.
It just REALLY annoys me when even managers that are supposed to be incharge of everything dont know doodie.
silentblackhat
Copper - Posts: 138
Posted: July 27, 2006 at 2:13 PM / IP Logged
no, it was at circuit city, when they had infinity. a while ago.  circuit city actually was clearing their subs and all inifnity stuff out(found out by the person that owrked in the car audio department) so i got the 1250w sub for $20 brand new(not display model at all).  i got 2 of them lol.
