Remote Starter Wiring Diagrams
pearsek
Posted: January 08, 2003 at 3:51 PM / IP Logged
I need wiring information (read color code wiring connections) for a 2003 Mitsubishi Outlander.  I have a Stellar Security System Remote Starter (Model RS1050 OEM Add-On) to install (for my Queen) and I could use the detailed hook-up wire info.  I can probably figure most of it out if someone can provide a vehicle wiring diagram with color coding.  Thanks for your help!
BTW, I could use the same information for a 2002 Mitsubishi Galant ES, Thanks, again.
pearsek
Montrealler
Copper - Posts: 155
Posted: January 10, 2003 at 5:58 PM / IP Logged
This is what i have on galant 2002 could this help ??? :-)
       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|blue / YELLOW         |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|  SECOND IGNITION|blue/black          |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|purple              |-  |either kick panel or *1     |
|     POWER UNLOCK|lt. GREEN/ red       |-  |either kick panel or *1     |
|       LOCK MOTOR|blue/red            |   |drivers kick panel          |
|     UNLOCK MOTOR|blue/black          |   |drivers kick panel          |
|    DISARM DEFEAT|blue/orange         |   |passenger kick panel        |
| PARKING LIGHTS +|GREEN / WHITE         |   |at the fuse box             |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|GREEN/ orange        |-  |top front of the fuse box   |
| DOME SUPERVISION|                    |   |                            |
|  TRUNK/HATCH PIN|white               |-  |at light in the trunk       |
|         HOOD PIN|blue/black          |-  |underdash fuse box          |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|red                 |-  |drivers door harness        |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|white               |   |instrument cluster or *2    |
|      SPEED SENSE|yellow/black        |   |instrument cluster or radio |
|       BRAKE WIRE|green               |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN / WHITE         |+  |*3                          |
|           WIPERS|blu/red, blu/org    |+  |wiper motor                 |
|  LF WINDOW UP/DN|RED / blk - grn/blk   |A  |drivers door switch         |
|  RF WINDOW UP/DN|RED / wht - grn/wht   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|green - yellow      |A  |drivers kick panel          |
|  RR WINDOW UP/DN|orange - grn/yel    |A  |drivers kick panel          |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.  Use DEI module 555U to bypass.  NOTE: When doing remote start on vehicles with factory alarm, must interrupt the blue/red (-) key sense wire at the steering column using the status output wire to bypass the factory starter kill.  *1 The door lock wires are in a black plug behind the fuse box, above a green module.  *2 On the 6 cylinder models, the white tach wire can also be found at the distributor. On the 4 cylinder models, the tach wire can also be found at the ignition failure sensor on the intake manifold, the white wire is in a 4 pin plug with three BLACK/ stripe wires.  *3 Horn relay in engine compartment relay box, or also found right at horn behind left side of front bumper.
Yes I'm Back 2006...
pearsek
Posted: January 10, 2003 at 8:32 PM / IP Logged
Thanks, Montrealler!! This is exactly what I need for my 2002 Galant. Now I need (most importantly) the
same information for my wife's 2003 Outlander.
Thanks, again.
pearsek
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
