Need 750-800 Watt RMS Amps
rboutin2
Copper - Posts: 90
Posted: June 01, 2006 at 9:59 AM / IP Logged
I need to know if anyone knows where to find two 750 or 800 watt rms amps cheap. I need them to push my 15" treos to their potential. They handle 750 rms, and i am only pushing them at 300 rms. they are dual 4 ohm subs, so i need a 2 ohm stable amp, that runs 750 or 800 rms at 2 ohms. I need to buy two of them, so I would prefer them as cheap as possible, but still good quality. Thanks!
xtremej
Gold - Posts: 1,440
Posted: June 01, 2006 at 10:08 AM / IP Logged
Cheap and good quality 750 - 800 rms. How cheap? Check this out it will easily push your 15's all day long and it price is good. These amps put out what they say they are also, be warned most cheap amp companies that throw around crazy numbers are generally very over-rated.
luckydevil
Silver - Posts: 365
Posted: June 01, 2006 at 10:33 AM / IP Logged
Why don't you just use one of the Treo amps?
SSXD1500.1
1500Wx1 RMS @ 2 Ohms
kirktcashalini
Silver - Posts: 492
Posted: June 01, 2006 at 8:26 PM / IP Logged
800RMS... at what ohms are your speakers wired for?
forbidden
Platinum - Posts: 5,354
Posted: June 01, 2006 at 10:32 PM / IP Logged
Dual 4 ohm subs, 2 subs = 1 ohm stable amp.
kirktcashalini
Silver - Posts: 492
Posted: June 02, 2006 at 6:05 AM / IP Logged
yeah I was out of it when i read it. I thought something was wierd how he wanted 2 ohm stable, but i thought itd be 1 or 4 ohm total impedence. Whats your budget man. (not like cheap, or mid price, but like $300? $500?)
rboutin2
Copper - Posts: 90
Posted: June 03, 2006 at 10:32 AM / IP Logged
i am going to wire one treo to one amp. Each treo handles 800 RMS. So, i need two amps. Each that push 800 rms at 2 ohms. And my budget is between $200 and $350 each.
stevdart
Platinum - Posts: 5,816
Posted: June 03, 2006 at 11:40 AM / IP Logged
Happy shopping!
Now, if I were selling something like in the days when I sold things, I would look at that highest figure and push it up to about $450.  Figure if someone says they can go as high as XX amount, you can automatically tack on another 25% or so to the figure.  In that range you can look at some suitable new amps.
Wire the subs together to 1 ohm and save some money and power resources by using one amp capable of a 1 ohm load.
Push up, back down a little.
That's why we have financing options  :)
