Installed a remote start/alarm - battery drain
Fruhead
Member - Posts: 11
Posted: January 09, 2003 at 12:13 AM / IP Logged
Any idea what would be causing a battery drain in an 86 Camaro? I have a starter kill hooked up to the alarm, and that should be the only thing activated other than the LED when the system is armed. The person said that his battery drains when the system is armed though. Any help would be appreciated... Thanks!
go2pac
Copper - Posts: 179
Posted: January 09, 2003 at 1:25 AM / IP Logged
Measure the current draw at the battery. It should be less than 40 ma. If that holds true then the battery probably has a bad cell and needs to be replaced. If the current draw is alot, then disconnect the alarm to see if its the culprit
Karl
Pacific Accessory Corporation
Mobile Audio Interfacing Equipment
Connecting You to Your Music Since 1976
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
