help with keyless entry install
bulldog
Posted: January 09, 2003 at 7:48 AM / IP Logged
I need help finding power door lock wires on my daughters 1998 altima. The wiring info says I should be able to find a grey wire and a purple wire at the module on the right hand of the steering column. I am not finding them. Anyone have a clue to help.
Thanks,
Mike
m-broome@raytheon.com
Mike
Montrealler
Copper - Posts: 155
Posted: January 10, 2003 at 6:05 PM / IP Logged
|              12V|WHITE/ red           |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|   SECOND STARTER|BLACK/ blue          |+  |ignition harness            |
|         IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|BLACK/ pink          |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ blue          |+  |ignition harness            |
|       POWER LOCK|gray                |-  |smart entrance control *1   |
|     POWER UNLOCK|purple              |-  |smart entrance control *1   |
|       LOCK MOTOR|RED / blue            |   |smart entrance control *1   |
|     UNLOCK MOTOR|yellow              |   |smart entrance control *1   |
|    DISARM DEFEAT|WHITE/ red           |   |smart entrance control *1   |
| PARKING LIGHTS +|RED / blue            |   |steering column             |
|       HEADLIGHTS|RED / yel(L),lt blu(R)|+  |steering column             |
|     DOOR TRIGGER|RED / white *3        |-  |drivers kick panel or SECU  |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|red or RED / blue     |-  |light in trunk              |
|         HOOD PIN|pink/black          |-  |smart entrance control *1   |
|  FCTRY ALARM ARM|lt GREEN/ red        |-  |smart entrance control *1   |
|FCTRY ALRM DISARM|GREEN/ YELLOW        |-  |smart entrance control *1   |
|       TACHOMETER|WHITE/ black         |   |6 pin plug at distributor   |
|      SPEED SENSE|PURPLE / red          |   |ECM, pin 26 *2              |
|       BRAKE WIRE|RED / green           |+  |brake pedal switch          |
|     HORN TRIGGER|brown or grn/yel    |-  |steering column             |
|           WIPERS|lt grn/rd,lt grn/blk|-  |steering column (L, H)      |
|  LF WINDOW UP/DN|green - blue        |A  |drivers window switch       |
|  RF WINDOW UP/DN|RED / wht - RED / blk   |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|yel/red - yel/blk   |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|grn/wht - grn/blk   |A  |drivers switch or kick panel|
Notes:
*1 The smart entrance control unit is located to the right of the steering column.  It is black or blue in color.  *2 The ECM is located in the front of the center console on the transmission hump.  *3 To avoid dome light delay use RED / green for the driver door, red for the front passenger door, and RED / black for the rear doors. All 3 three wires are located at the smart entrance control unit. Must diode isolate each.
Yes I'm Back 2006...
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
