Is 200ma output strong enough, 4 relays?
CutDog504
Silver - Posts: 643
Posted: June 09, 2006 at 9:54 AM / IP Logged
My alarm has 200ma outputs. But is a 200ma output strong enough to trigger 4 relays? I need to trigger 4 relays at the same time using only one output. Should I be ok connecting the output to 4 relays or will I have to wire up a 5th relay to trigger the other 4? The 5th relay would be the only one triggered by the alarm output, then it would send a ground to the other 4 relays. Has anyone done something like this before?
the12volt
Administrator - Posts: 3,959
Posted: June 09, 2006 at 9:57 AM / IP Logged
I'd use the fifth relay.
Is 200ma output strong enough, 4 relays? - Last Post -- posted image. the12volt • Support the12volt.com
djfearny2
Silver - Posts: 810
Posted: June 09, 2006 at 10:18 AM / IP Logged
like 12 volt says use one relay to step it up first.
so a total of five relays
so hook up one to be trigger by the 200ma then ground it so it is much higher it will protect your self in the future so you dont blow out that trigger wire.
Jon
Installer/Help Technician
---coral springs florida---
CutDog504
Silver - Posts: 643
Posted: June 09, 2006 at 10:27 AM / IP Logged
Thanks, thats what I figured I should do anyways. Just makin sure.
