Compustar 2W900FM-AS starter kill
bbtaco
Copper - Posts: 119
Posted: June 18, 2006 at 9:18 PM / IP Logged
Does the starter kill on this RS also work as an anti grind when the vehicle has been remotely started?
spookiestylez
Silver - Posts: 531
Posted: June 18, 2006 at 11:16 PM / IP Logged
if on the remote start harness it has a wire for the starter(key side) and starter (motor side) then it should
rtfm
aceracer24
Copper - Posts: 140
Posted: June 19, 2006 at 12:36 AM / IP Logged
I think this is an option that MUST be turned on either by the shop that installed or you can if you have the manual. It tells how to do it.
1968 VW Beetle
Pioneed DEH-780MP, 2 10' Memphis PR104D, Memphis PR500.1, TXC 6.1, MTX Thunder 8502
bbtaco
Copper - Posts: 119
Posted: June 19, 2006 at 11:19 AM / IP Logged
I hooked it up according to these instructions:
Pin #6: Yellow- This wire is the (+) Starter output. This is pre-wired tothe starter-kill relay for ease of installation. At the starter-kill relay youwill see a yellow and yellow/black. These wires are used to interrupt thestarter wire in the vehicle. You will need to cut the starter wire in halfand connect the wire accordingly: Yellow/Black will connect to the keyside and the yellow will connect to the motor side (starter side).
aceracer24
Copper - Posts: 140
Posted: June 19, 2006 at 11:52 AM / IP Logged
Sorry, I got anti jack and anti grind confussed :) Anti-grind should be automatic as long as you have everything connected correctly...as far as I know.
1968 VW Beetle
Friday, July 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
