Subwoofer Wire Splicing?
scubasteve2011
Member - Posts: 14
Posted: June 24, 2006 at 8:32 PM / IP Logged
Hey there.  Well, I'm getting ready to wire my 2 subwoofers exactly like the picture shown below @ 2 ohms. But what I dont understand is how I am supposed to splice into the wire?  As you can see, the teal wire runs to both the 1st and the 2nd subwoofers, but how do I make a good clean connection out to both?Subwoofer Wire Splicing? - Last Post -- posted image.
mustangfoo
Silver - Posts: 371
Posted: June 24, 2006 at 8:39 PM / IP Logged
if u have them in seperate chambers and then seperate terminals, then you can just run both sets of wires to your amp, your amp will see the subs as being wired just as you have pictured.
DYohn
Platinum - Posts: 10,741
Posted: June 24, 2006 at 9:26 PM / IP Logged
The wires are not spliced.  When an electrical diagram show two wires branching off one another it simply means they are connected to the same point.
mobilesndfx
Copper - Posts: 49
Posted: June 24, 2006 at 9:27 PM / IP Logged
Solder a wire from the positive lead on sub A to the positive lead on sub B. Do the same with the negative lead. Then solder a wire from the positive and negative terminals. This way, you only have 1 wire running from each polarity
Alpine 9835, MB Quart components, (3) JL Audio 10w3v2, JL Audio 500/1, JL Audio 300/4, Streetwires wiring
scubasteve2011
Member - Posts: 14
Posted: June 24, 2006 at 10:02 PM / IP Logged
Awesome guys, I got it under control.  Except for one thing.  How much better is it going to be having 8 gauge wire compared to 14 gauge wire?  Ive been told that 8 is much better, but thena gain, ive also been told that it doesnt matter.  The thing is that ive got 14 avilable right now, and it will take a bit of time to get some 8.  thanks!
mobilesndfx
Copper - Posts: 49
Posted: June 24, 2006 at 10:12 PM / IP Logged
If your talking speaker wire, your probably fine. Power wire might be another issue
furflier
Copper - Posts: 236
What are you using the wire for ? If it is for speakers 14 gauge is fine. If  it's for power use don't use nothing less then 8gauge.
scubasteve2011
Member - Posts: 14
Posted: June 24, 2006 at 10:21 PM / IP Logged
Yes, it is the wire going from the subwoofers back to the amp.  So 14awg will be fine?  If so, i'm gonna get these babies wired tonight!
mobilesndfx
Copper - Posts: 49
Posted: June 24, 2006 at 10:24 PM / IP Logged
your good with 14 ga. Wire them up and enjoy!!
stevdart
Platinum - Posts: 5,816
Posted: June 25, 2006 at 9:28 AM / IP Logged
Here's another way to see the same wiring diagram.  Probably more like they would look in real life:
