Avic N1 and GMC Security Issues ?
jrcactus
Posted: June 25, 2006 at 2:56 PM / IP Logged
I put in a Pioneer Avic-N1 into my 1998 GMC Serria about a month ago and had no issues for about a week after the install was done, since then about once a week my Security light comes on the dash and after a few more off and on's with the ignition the vehicle wont start.
It started by going into the shop and the vehicle not starting, it would turn over and only stay running for about 3 seconds. To make a long story short once the Avic was un-plugged the truck fired right up. Another week or so went by and same thing happend, truck wont start so un-plugged the head unit and the truck would start. My dad own's a automotive shop and we used the scanner and it come up with the code P1626(Anti theft Device) we thought it may have been the ignition cylinder getting worn out so we replace it and coded it to the vehicle.
Truck ran fine for a day or so and same thing is happening again, sad new is the factory head unit is back in and it causing the same issues. Has anyone come across this happening to them or anyone they know? I have googled the topic and found a crap load of info but no one has really said what the cause was.
I did the install on the unit myself  and have knowledge as I was a installer for 6 years, all that was installed was a factory wire harnes and mounting kit.
Thanks,
Jr
auex
Platinum - Posts: 5,041
Posted: June 25, 2006 at 11:53 PM / IP Logged
It sounds like one of the imobilizer wires was tapped for something. Check the wiring coming off of the cylinder. The three wires are orange, black, yellow. There could be different color wires as well. Do you have an aftermarket alarm/remote start installed as well?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
jrcactus
Posted: June 26, 2006 at 12:02 AM / IP Logged
No everything is stock
sparkie
Platinum - Posts: 2,061
Posted: June 26, 2006 at 4:24 PM / IP Logged
You need to use a scan tool to view the Passlock II system data. Look for the whether or not the vehicle theft deterent module is disabling the fuel system. If it is then you have a problem with the Passlock II wiring or circuits inside the igntion cylinder. If the theft system isn't disabling the fuel system, then you need to look elsewhere for the problem. If all you used was a radio harness plug then it has nothing to do with the problem. Did you however hook up the reverse, VSS and parking brake circuits to the new head unit? Maybe thes are the problem.
sparky
gregory863
Copper - Posts: 112
Posted: June 26, 2006 at 5:41 PM / IP Logged
where did you tie in the vss wire? and did you use a wireharness adaptor?
I can eat fifty eggs
jrcactus
Posted: June 26, 2006 at 10:39 PM / IP Logged
It is dissabling the Fuel, it runs for the 3 seconds and then shuts the injectors down. VSS and rearview are not hooked up.
I had the column apart today and all wires look just like new, I checked voltage at the top near the cylinder at the 3 wires for passlock and the voltage was the same at the top as it was at the main plug under the dash near the steering column.
The security light will not come one when it wont start when the key is first turned to the run position, when it does start the security light turns on for 5-7 seconds then off it goes and it starts like normal.
