Tiburon with Infinity System wire harnes
Walkercustoms
Copper - Posts: 219
Posted: July 04, 2006 at 9:17 AM / IP Logged
We need some help here. I had a customer go to Best Buy Saturday to pick up a new deck and harness for is 03 Tiburon and the guy there told him there was no harness for the infinity systme and that an aftermarket HU is not going to work. We I know I should no have sent him there but we did not have any decks and he wanted on that day and because the great help at Best Buy he still does not have one. I need to know the model number and the maker of a harness for the Tiburon with the infinity systme so he can use his factory speakers on the new deck. We had to use a hi to low converter for now and he really wants a new deck. If they do not make one what is the wireing I need to do to get a new HU to work with the factory amp and speakers.
Wade
Platinum - Posts: 12,488
Posted: July 04, 2006 at 9:44 AM / IP Logged
Check to see that the harness at the amplifier is the same as the HU. Some manufacturer's use the same harness for both so there is no need for a separate adaptor harness for the amp. If the harness is different, then you will need to test the output of the amplifier and run the speaker outputs from the aftermarket HU to the OEM amplifier outputs. It's not impossible, just a little more work to charge out to the customer.
Walkercustoms
Copper - Posts: 219
Posted: July 04, 2006 at 10:20 AM / IP Logged
That is what we figured and when I told him that its going to be more time and extra cash he was like will bestbuy have a harness.
