1998 Dodge Ram Pick up
qworld
Posted: July 13, 2006 at 3:38 PM / IP Logged
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1998&make= Dodge&model=Ram%20Pickup&ID=17655&type=Stereo
On that link it says that the starter wire is YELLOW.
There is NO yellow wire in the steering column. Does anyone know the true color of the start wire?
Thank you.
josh1979
Silver - Posts: 320
Posted: July 13, 2006 at 6:08 PM / IP Logged
the info for a 98 and 99 i have says yellow too. the info to follow is for a 97 see if this mates up
12volts red or pink/black   +  ignition harness
Starter blue / YELLOW   +  ignition harness
Second Starter
Ignition dk. blue   +  ignition harness
Second Ignition
Third Ignition
Accessory BLACK/ orange  +  ignition harness
Second Accessory BLACK/ white  +  ignition harness
Keysense
Power Lock ORANGE / purple    lt blue plug in driver kick
Notes: Positive trigger on models with factory keyless entry, and 5 wire on all other models.
Power Unlock pink/purple    lt blue plug in driver kick
Lock Motor
Unlock Motor
Parking Lights+ BLACK / YELLOW    yellow plug in driver kick
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow   -  yellow plug in driver kick
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer gry/blk, blk/gry  AC  coil pass. side engine
Notes: Also located as gray/blue at large plug through firewall on drivers side at highest point of firewall, also gray/blue at cluster.
Diesel tach wire is gray/black, located at the PCM on the passenger side firewall or in the main harness that runs along the firewall.
Wait to start ORANGE / black  -  PCM on passenger side firewall
Notes: See DirectFax document 1090.
Also located in the main harness that runs along the firewall.
Brake Wire WHITE/ brown   +  brake pedal switch
Parking Brake
Horn Trigger dk. GREEN/ red   +  relay at fuse box
Notes: Also BLACK/ red (-) at column or relay.
Memory Seat 1
Memory Seat 2
Memory Seat 3
1998 Dodge Ram Pick up - Last Post -- posted image.
bring back the rotary phone so i dont have to press 1 to proceed in english
qworld
Posted: July 14, 2006 at 7:23 AM / IP Logged
Thank you. I'll give it a look-see.
