hi-low beam relay
holoman
Posted: January 13, 2003 at 5:16 AM / IP Logged
Hi!
I would like to use a relay to change between the high and low beam on my motorcycle. The button to control this is a push button. Actually a microswitch kind of type. So every time I send a pulse to the relay, it should switch between low and high. And if nothing is sent to the relay, it should just keep the power as is.
I have only found a relay that keeps the low beam on when I keep the button switch, but as soon as I let go with the button it jumps back to the high beam again.
I also must mention that there is very limited space available to mount the relay. There is room for a normal bosch relay, but not two.
finnman925
Member - Posts: 19
Posted: January 13, 2003 at 7:15 AM / IP Logged
search for a latching relay - shouild be able to find on the web,
Brian
hotrodelectric
Copper - Posts: 112
Posted: February 27, 2003 at 10:55 PM / IP Logged
Maybe have room for a Saab 900 (85-90 yr) headlight relay? They are nearly twice the size of a standard Bosch
relay, but it's all in one can, and they're easy to hook up. Or maybe a relay from a 9000- these are the same size as a single Bosch, but you'll have to check that out a little more carefully.
