Self-Amplified sub
kirktheninja
Posted: August 06, 2006 at 10:06 PM / IP Logged
Hello, I tried to install my self-amplified sub and its not working. I followed these instructions given in the package:
There are 4 connections necessary
for proper operation of the BA-1 00.
(See figure B)
1. 12 Volt (12V): Connect this wire to
a source of + 12 volts which does not
turn off with the ignition key. It may
also be connected directly to the
positive (+) terminal of the battery.
2. Ground (GND): Secure this wire
using a screw or bolt on a grounded
metal surface of the vehicle. Clean
away any rust, dirt or paint from the
surface to make sure a good connection
is made.
3. Speaker Input Positive (SPK +):
Splice this wire to the wire going to
the p.ositive (+) terminal of the
speaker that you have chosen
(sometimes indicated by a red dot).
4. Speaker Input Negative (SPK -):
the negative (-) terminal of the
speaker that you have chosen.
This completes the wiring of the
BA-100. Re-check all connections to
make sure they are secure.
Is there anything that i could be missing since my sub doesn't work. All of the wires are connected to their designated colors. When I connect my ground wire to a metal surface of my car , the lock of my car lock themselves does this mean anything?
Thank you for reading and your help will be ver appreciated.
cloak559
Copper - Posts: 215
Posted: August 07, 2006 at 12:22 AM / IP Logged
Find a different spot to ground it...
'89 Mercedes-Benz 300E
Pioneer DEH-5900UB
(2)RE Audio SX 10"s
(1)US Amps MD3D
3ft^3 @ 37Hz
Blowing up in a car accident doesnt worry me, as long as I'm putting out some major dB's when I die...
kirktheninja
Posted: August 07, 2006 at 12:54 PM / IP Logged
i just tried that an no luck still. but whenever i move the ground wire against a metal surface my sub makes a crackle noise in spirts.
cloak559
Copper - Posts: 215
Posted: August 07, 2006 at 9:13 PM / IP Logged
so wait...you had power running to the unit while you were moving the ground wire around???
Pioneer DEH-5900UB
(2)RE Audio SX 10"s
(1)US Amps MD3D
3ft^3 @ 37Hz
kirktheninja
Posted: August 08, 2006 at 12:09 PM / IP Logged
nope, when it was moving under the electrical tape, when i was testing different spots.
