Subsonic Filter
alpine_king
Copper - Posts: 73
Posted: August 10, 2006 at 2:39 PM / IP Logged
I have done a few searches on here but i didnt find what i was looking for. I just hooked up 3 10 inch comp vr's to my 1000 watt rms mrd-m1005, they are running at 2 ohms. i see kicker says that turning on a subsonic filter will greatly increase the power handleing of the subs, so im just wondering how it works. the settings on the amp are either 15 hz, or 30 hz. say i have it on 15, does that mean anything 15 and lower will not be played? i just dont really know how the filter works thats all, and the lowest these 10's will hit is 25 hz. thanks alot guys.
1993 Ford Ranger.
Head Unit.Alpine CDA-9831
Front Speakers.Infinity 6010 Reference Series
Amp.Alpine MRD-M1005
Subs.3 Kicker CVR10
Rear Speakers.SPL CS-573
20" Boss 312's, lowered 3/4
alpine_king
Copper - Posts: 73
Posted: August 10, 2006 at 2:50 PM / IP Logged
alright, yah i was just wondering about it, i saw kicker said to turn it on so i figured i'd find out why. they are dual 4 ohms
1993 Ford Ranger.
Subs.3 Kicker CVR10
Flakman
Copper - Posts: 365
Posted: August 10, 2006 at 2:58 PM / IP Logged
If you have the 10s in a ported box, the filter may keep them from having problems with over excursion. I don't know if performance will be much of a problem, especially in a sealed box. Those tones are too low to hear and if the music you are playing doesn't contain tones that low, the filter won't be filtering out much anyway. Of course, turning the filter on won't hurt anything...you could turn it on to 15, play it a while, then turn it to 30 and see if you can tell any difference. Let that be your guide. I would just advise turning it on if your box is ported if there is no difference between settings.
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
alpine_king
Copper - Posts: 73
Posted: August 10, 2006 at 3:01 PM / IP Logged
yah they are in a sealed box getting about 1.75 ft3 each, thanks for ur guys quick replies. i appreciate it.
1993 Ford Ranger.
Subs.3 Kicker CVR10
12vdeej
Member - Posts: 26
Posted: August 10, 2006 at 3:38 PM / IP Logged
Just so you know alpine_king, three dvc subs wired as 2 ohms each will present a 1.3 ohm load to the amp when wired in parallel. Your amp is rated to 2 ohms so you are damaging it by doing this. If you wire each dvc sub as 8 ohms (coils in series) the amp will see a 2.6 ohm load. This will reduce the power that the subs will recieve, but you won't be pushing the amp past its limitations. Back to your original question, even though the subs are in a sealed box, im virtually certain that you won't be able to hear the difference between turning the filter to 30hz (the safer option), or not using it at all so you may as well do it.
alpine_king
Copper - Posts: 73
Posted: August 10, 2006 at 4:29 PM / IP Logged
yeah i know, they will be running at 2.6. im runnin like 14.3 volts all the time, so they will still be hitting good, better then my one type r i had anyways.
1993 Ford Ranger.
Subs.3 Kicker CVR10
Aruman
Silver - Posts: 363
Posted: August 10, 2006 at 4:50 PM / IP Logged
sealbox, let the SubSonic Filter off.
Shaking The Neighborhood
