hyundai accent 2001
lex305
Member - Posts: 8
Posted: August 12, 2006 at 5:47 PM / IP Logged
any1 has the color diagram for a hyundai accent 2001? the one that shows is not even close to the colors in their.i got power but no ground for the 7in t-view monitor.
lex
josh1979
Silver - Posts: 320
Posted: August 12, 2006 at 7:40 PM / IP Logged
HYUNDAI / ACCENT / 2001 / Remote Start
12voltsred + ignition harness
Starterwhite + ignition harness
Second Starter
Ignitiongreen + ignition harness
Second Ignition
Third Ignition
Accessoryyellow + ignition harness
Second Accessoryblue + ignition harness
Notes: This wire is not required for remote start.
Keysense
Power Lockadd actuator in driver door
Notes: Vehicle with keyless entry use BLACK/ orange for lock and yellow for unlock. They are negative trigger and found at the ETACS module to the left of the steering column.
Power Unlocksame
Lock Motor
Unlock Motor
Parking Lights+grn/org(L),grn/blk(R driver kick panel
Parking Lights-green headlight switch
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Triggergreen - driver kick panel or cluster
Dome Supervisionuse door trigger
Trunk/Hatch PinGREEN/ orange - driver kick panel or cluster
Hood Pinyellow/black - pin switch
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometergray ECM under driver dash, pin 8
Notes: Can also use blue or brown at the ignition coils.
Wait to start
Brake Wirepink/black + brake pedal switch
Parking Brake
Horn Triggerblue/orange - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
hyundai accent 2001 - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
No
Type:
N/A
Part #: N/A
Headlightyellow - headlight switch
Trunk/Hatch Release
Power Sliding Door
Speed SenseWHITE/ black or blue/black data link connector
Notes: The data link connector is under the driver side dash.
Wipersgreen (L), brown (H) - steering column
LF Window up/dnblue - green A driver window switch
RF Window up/dngray - orange A driver kick panel
LR Window up/dnblack - green A driver kick panel
RR Window up/dnwhite - blue A
Radio 12vORANGE / black + radio
Radio Groundblack - radio
Radio Ignitionblue/black + radio
Radio IlluminationGREEN/ orange + radio
Factory Amp Turn-on
Power Antennapink + radio
LF Speaker +/-red - blue radio
RF Speaker +/-white - brown radio
LR Speaker +/-green - orange radio
RR Speaker +/-orange - blue radio
bring back the rotary phone so i dont have to press 1 to proceed in english
josh1979
Silver - Posts: 320
Posted: August 12, 2006 at 7:43 PM / IP Logged
Second Starter
Second Ignition
Third Ignition
Keysense
Power Unlocksame
Lock Motor
Unlock Motor
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Wait to start
Parking Brake
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass
Required:
No
Type:
N/A
Trunk/Hatch Release
Power Sliding Door
RR Window up/dnwhite - blue A driver kick panel
Factory Amp Turn-on
