Are distribution block fuses needed?
rabreedlove
Member - Posts: 13
Posted: August 12, 2006 at 6:13 PM / IP Logged
I'm going to be connecting up a Rockford Fosgate P450.4 (60W RMS x 4 4-ohm) and a Rockford Fosgate P200.2 (200W x 1 4-ohm bridged) amps.  My wiring kit contains a main fuse at the battery and a distribution block, but no fuses at the distribution block.  I've seen several wiring diagrams during my research that show additional fuses at the distribution block.
For this system, do I really need this?
Thanks for the advice.
haemphyst
Platinum - Posts: 5,059
Posted: August 12, 2006 at 6:25 PM / IP Logged
If you are transitioning to a smaller size wire on the output side of the distro, YES!!! Absolutely!
killer sonata
Silver - Posts: 718
Posted: August 12, 2006 at 6:43 PM / IP Logged
its generally a good idea to use them. It wont hurt anything to use too many. If the run between the battery and the distro block and the destination is fairly short, youd probably be safe not using them. all depends on the equipment and wiring being used too.
rabreedlove
Member - Posts: 13
Posted: August 12, 2006 at 11:33 PM / IP Logged
Yeah, I know that the 8-gauge amp wire downstream of the distribution block might not be able to carry the load of the 100-amp fuse on the 4-gauge wire at the battery terminal.  I just find it very interesting that almost no dual-amp wiring kits come with secondary fuses.
I work in a power plant.  I may grab a piece of the 8-gauge wire and test it next week to see how much current it carries at 12V before it smokes.  That would be interesting!!!!
darthness
Copper - Posts: 136
Posted: August 13, 2006 at 12:27 AM / IP Logged
its worth the extra few bucks for the fuse.
i'm pretty sure $2 is a lot less of deal than what ever it'd take to replace anything that coudl be damaged by fire :P
Monday, July 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
