normaly closed relay?
tmg115
Posted: August 12, 2006 at 6:23 PM / IP Logged
ok i am going to try and explain what i need for my truck so hear it goes. i need a device that will splice in between a wire that will alow electric current to flow. but when i put electricity to the device it will stop the electric flow.
Kinda like a reverse relay.
this will be going on an extra brake light i have and i need to turn off the brake light when i flip the switch to run my emergency flashers.
I think what i need is a normaly closed relay but i am not sure.
i hope i explained that well enough.
Can some one tell me what this device is called and where i can get one?
I am a retard when it comes to electronics so you will have to tell me the answer as simply as possibol.
Thanks for the help guys
Tom
P.S. I made a very crappy picture of what i need done.
normaly closed relay? - Last Post -- posted image.
i put way to much stuff on my truck
tmg115
Posted: August 12, 2006 at 6:25 PM / IP Logged
Oh and what ever i need has to be water and weather proof because it will be mounted under my truck bed.
Thanks again
Tom
josh1979
Silver - Posts: 320
Posted: August 12, 2006 at 7:22 PM / IP Logged
if you are conecting just one small brake light this will work with a SPDT (Single Pole Double Throw Relay) Automotive Relay  that can be purched at anu auto parts store ad if taped up is small enough to maybe mount behind you oem tail light
1. if your flasher switch sends a neg. trigger to turn on the flashers read pin 86 as to neg. from flasher switch and read pin 85 as to +12v batt.
bring back the rotary phone so i dont have to press 1 to proceed in english
tmg115
Posted: August 12, 2006 at 9:22 PM / IP Logged
thank you very much. i will try this monday and see if it works.
And my flasher switch sends a + trigger.
Thank you all again.
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
