Is it ok to use the Bule Remote lead for
mjt1405
Posted: August 13, 2006 at 8:43 PM / IP Logged
Is it ok to use the Blue remote lead for the yellow ACC? It will be for a Pioneer XM radio box and the AVIC N3. Thx for the info MJT
auex
Platinum - Posts: 5,041
Posted: August 13, 2006 at 8:49 PM / IP Logged
Yellow acc? Yellow is usually constant, red is usually for acc. Also the blue remote lead doesn't supply much power so even if you did use it for a power lead you would need to use a relay.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
mjt1405
Posted: August 13, 2006 at 9:33 PM / IP Logged
Sorry your right im losing it... Would it be ok to use the red controlled by ignition switch as the blue then and not have to use a relay
Moderator - Posts: 12,488
Posted: August 13, 2006 at 11:25 PM / IP Logged
Yes you can but how many devices will you be using ? If you just using it for the XM radio then it's fine.
mjt1405
Posted: August 14, 2006 at 5:48 PM / IP Logged
Well XM and 1 amp for now
oxygen65
Silver - Posts: 252
Posted: August 30, 2006 at 9:34 PM / IP Logged
could you run 6 7 inch monitors off of the red acc wire or what would you have to do to give power to the 6 monitors when your car turns on?
killer sonata
Silver - Posts: 718
Posted: August 30, 2006 at 10:15 PM / IP Logged
if you use relays you should be good.
oxygen65
Silver - Posts: 252
Posted: August 30, 2006 at 10:45 PM / IP Logged
how do you hook up a relay to the acc wire?
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
