2007 Toyota Yaris Alarm/Remote Start/Stereo Wiring
wayside
Posted: August 16, 2006 at 1:08 PM / IP Logged
Hello all,
I am in search of the wiring schematic for the aforementioned vehicle.
I would like to install an alarm. I would also like to automate the power windows and provide power to the stereo via a switched alarm channel.
Thank you,
Wayside
josh1979
Silver - Posts: 320
Posted: August 19, 2006 at 9:58 PM / IP Logged
TOYOTA / YARIS / 2007 / Remote Start
[PRINT THIS PAGE]
12voltsyellow (25A), gray (15A) + ignition harness
Starterblack (x2)(common) + ignition harness
Second StarterN/A
Ignitionpink + ignition harness
Second Ignitiongreen + ignition harness
Third IgnitionN/A
Accessorywhite + ignition harness
Second AccessoryN/A
Keysenseyellow - ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Power Lockbrown - driver kick, 20 pin plug, pin 7
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlockyellow to green (double pulse) - driver kick, 20 pin plug, pin 8
Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is green (-) at the fuse box, middle, 18 pin plug, pin 15.
Lock Motorwhite to orange 5widriver kick, 20 pin plug, pin 10
Unlock Motorlt. blue to pink 5widriver kick, 20 pin plug, pin 20
Parking Lights+green + fuse box, top L, 30 pin plug, pin 29
Parking Lights-white - headlight switch
Notes: Not available on all models.
Hazardsblack - hazard light switch
Turn Signal(L)lt. green + fuse box, top L, 30 pin plug, pin 27
Turn Signal(R)yellow + fuse box, top L, 30 pin plug, pin 28
Reverse Lightred + fuse box, top L, 30 pin plug, pin 30
Door Triggersee notes - fuse box, top left, 30 pin plug
Notes: The LF door is red in pin 21. The RF door is blue in pin 24. The LR door is green or yellow in pin 5. The RR door is blue in pin 20. The rear doors are common on some models. Use all four wires and diode isolate each.
Dome Supervisionpink - fuse box, L side, 6 pin plug, pin 2
Trunk/Hatch Pinlt. blue - fuse box, top L, 30 pin plug, pin 7
Hood Pinwhite - pin sw or theft warning ECU, pin 4
Notes: The theft warning ECU is behind the glovebox.
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Armarms with lock
Factory Alarm Disarmdisarms with unlock
Disarm No Unlockuse key sense wire
Tachometerlt. green ac data link conn. under dash, pin 9
Wait to startN/A
Brake Wiregreen to purple + fuse box, top L, 30 pin plug, pin 12
Parking Brakeyellow - fuse box, top R, 16 pin plug, pin 2
Horn Triggerblack to lt. green - fuse box, top, 36 pin plug, pin 28
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
2007 Toyota Yaris Alarm/Remote Start/Stereo Wiring - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Optional on the sedans and S sedans, not standard equipment.
Headlightlt. blue - headlight switch
Speed Sensepurple fuse box, top, 36 pin plug, pin 26
Wipersblue (L), yellow (H) + windshield wiper switch
LF Window up/dnred - green A driver window switch in door
RF Window up/dnwhite - pink A driver kick, 18 pin plg, pins 11, 10
LR Window up/dnyellow - black A driver kick, 18 pin plug, pins 8, 9
RR Window up/dnred - green A driver kick, 18 pin plg, pins 17, 18
Radio 12vblue + radio harness
Radio GroundWHITE/ black - radio harness
Radio Ignitiongray + radio harness
Radio Illuminationgreen + radio harness
Factory Amp Turn-onN/A
Power Antennablack + radio harness
LF Speaker +/-pink - purple +,-radio harness
RF Speaker +/-gray - yellow +,-radio harness
LR Speaker +/-black - yellow +,-radio harness
RR Speaker +/-red - white +,-radio harness
bring back the rotary phone so i dont have to press 1 to proceed in english
wayside
Posted: September 17, 2006 at 8:59 AM / IP Logged
Thanks Josh
Wayside
