remote starter
latino
Posted: January 15, 2003 at 6:38 PM / IP Logged
 how would you install a remot car starer on a '89 Acura Integra??
you never had me you never had your car
Platinum - Posts: 12,488
Posted: January 16, 2003 at 9:56 AM / IP Logged
|              12V|WHITE/ black         |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|BLACK / YELLOW        |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ red *1        |+  |ignition harness            |
|       POWER LOCK|GREEN / WHITE         |-  |driver kick panel           |
|     POWER UNLOCK|GREEN/ red           |-  |driver kick panel           |
|       LOCK MOTOR|yellow/red          |   |driver kick panel           |
|     UNLOCK MOTOR|BLACK/ red           |   |driver kick panel           |
|    DISARM DEFEAT|WHITE/ red           |   |passenger kick panel        |
| PARKING LIGHTS +|RED / black           |   |headlight switch            |
|       HEADLIGHTS|RED / yellow          |+  |headlight switch            |
|     DOOR TRIGGER|GREEN/ red           |-  |integrated control unit *2  |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|GREEN/ black         |-  |driver kick panel           |
|       TACHOMETER|blue                |   |distributor                 |
|      SPEED SENSE|yellow/red          |   |instrument cluster or PCM *3|
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|blue/red *4         |-  |steering column             |
|           WIPERS|blu (L), blu/yel (H)|-  |steering column             |
|  LF WINDOW UP/DN|blu/red - blu/wht   |A  |driver window motor         |
|  RF WINDOW UP/DN|blu/yel - blu/grn   |A  |driver kick panel           |
|  LR WINDOW UP/DN|grn/yel - green     |A  |driver kick panel           |
|  RR WINDOW UP/DN|yellow - yel/grn    |A  |driver kick panel           |
| SUN RF OPN/CLOSE|grn/red - grn/yel   |C  |sun roof switch             |
|        RADIO 12V|WHITE/ blue          |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|yellow/red          |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|blu/grn - gry/blk   |   |radio                       |
|       RF SPEAKER|RED / grn - brn/blk   |   |radio                       |
|       LR SPEAKER|blu/yel - gry/wht   |   |radio                       |
|       RR SPEAKER|RED / yel - brn/wht   |   |radio                       |
Notes:
*1 Not required for remote start.  *2 The integrated control unit is on the right side of the fuse/relay block under the driver side dash.  *3 The PCM is under the passenger seat.  *4 This wire is high current negative, MUST use relay.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
