Strechy material not fleece
jw007
Member - Posts: 7
Posted: September 19, 2006 at 12:12 PM / IP Logged
I have built a few boxes using fleece to stretch to the shape I want. I don't really like using it, though. It's pretty thick. I was wondering if someone had an online source for somthing more like a sheet of pantyhose material. I know nothing like that is available locally as I have searched everywhere. So it would need to be an online source.
Thanks,
Jason
killer sonata
Silver - Posts: 718
Posted: September 19, 2006 at 12:22 PM / IP Logged
felt is pretty stretchy and not nearly as absorbant or thick as fleece.  easy to get too. just go to your local fabric store.
sprawl85
Copper - Posts: 204
Posted: September 19, 2006 at 12:33 PM / IP Logged
speaker grill cloth from partsexpress.com
fiberglass reminds me of peanut brittle... but fiberglass tastes better!
Melted Fabric
Silver - Posts: 509
Posted: September 19, 2006 at 1:30 PM / IP Logged
I second that. Felt is good though, too.
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
bellsracer
Silver - Posts: 703
Posted: September 19, 2006 at 2:13 PM / IP Logged
Pretty much any polyester material would be ideal for fiberglassing work.
As for websites, we like yourautotrim.com. The're not the cheapest place, but give a strong spring for finding what we are looking for. Otherwise check the clearance areas of fabric shops and look for fabrics made of polyester. It'll give the best bond for the resin.
jw007
Member - Posts: 7
Posted: September 20, 2006 at 2:09 PM / IP Logged
I was looking for super strechy material. It doesn't have to be thick, because I'm adding matt over top of it. I just need the initial material to give me the shape.
jason
PS: Thanks for the repsonses
pmh61
Copper - Posts: 151
Posted: September 20, 2006 at 3:33 PM / IP Logged
try something called polydex its like swimsuit material, you don't even have to staple it down you can use CA glue and it will hold it in place then you can resin it the matt it to make it thicker and it is very very strechy and ploydex= polyester and spandex cost more than fleece but it works good
bellsracer
Silver - Posts: 703
Posted: September 20, 2006 at 7:38 PM / IP Logged
nouseforaname wrote:
it doesn't nessisarily have to be a polyester material. in some cases, an old cotton t-shirt is just fine. it really depends on how much stretch you need. the amount of resin it soaks up and how strong it will be are also important.
We didn't say it had to be polyester but most people use polyester resin for their jobs, using polyester cloth actually cures into the resin and chemically becomes part of the resin. Essentially it welds in rather than bonding via capillary effect. Cotton workds great too, just a slightly different physics in it.
