2003 Honda Civic LX Sedan
anton1606
Member - Posts: 7
Posted: September 19, 2006 at 4:18 PM / IP Logged
Hey I really need to know the Stereo/CD Player wiring codes for my car, I have no clue which wire does what or what it is for, I searched everywhere but no luck, If anyone can just give me the codes for my cars stereo system I would be happy. And one more thing, I accidently connected the wrong wire to the wrong place and my cd player and stereo system went dead, now i cant ever turn it on again....is there like a reset button or would i have to find the fuse because it might be burned out.
aaa
KarTuneMan
Platinum - Posts: 7,056
Posted: September 19, 2006 at 11:49 PM / IP Logged
+12V DC Battery(Constant)WHITE/ red Pin A10 10 amp Fuse box at right side of engine compartment
Switched AccessoryYellow/red Pin A2 7.5 amp Fuse box under left side of dash
Ground Black Pin A20
Illumination RED / black Pin A9
Dimmer Red Pin A19
Left Front + GREEN/ black Pin A7
Left Front - Light green Pin A17
Right Front + GREEN/ black Pin A8
Right Front - Light green Pin A18
Left Rear + Blue/white Pin A6
Left Rear - Blue/black Pin A16
Right Rear + Pink Pin A5
Right Rear - Blue / YELLOW Pin A15
2003 Honda Civic LX Sedan - Last Post -- posted image. AT SPEAKERS
Wire FunctionColorNote
Left Front Mid + GREEN/ YELLOW
Left Front Mid - Grey/red
Your deck MIGHT be dead.....If you ever put an aftermarket deck in another car....get a harness adapter from Metra. www.metraonline.com  Good luck
anton1606
Member - Posts: 7
Posted: September 20, 2006 at 1:08 PM / IP Logged
Thanks for the diagram....but about the deck, i don't think its dead, cuz the stock one doesnt work and the other 2 that ive tried, im 100 percent sure i hooked up the right wires to the right place. the stock deck stoped working when i was installing my amp and accidently touched the wire from the amp to the stock decks +12V DC Battery wire while battery was pluged in, so can it be that some kinda fuse burned out? and if so where would i find that certain fuse...ill check every fuse just incase it any are burned out...
aaa
anton1606
Member - Posts: 7
Posted: September 20, 2006 at 2:37 PM / IP Logged
Okay nevermind I got it to work, KarTuneMan thanks alot for the Wiring Diagram it really helped, the fuse information is what helped the most, All i needed to do was to change a few Fuses under the hood and dash and everything seems to be working now. Deck bumps well on my subs without amp. Thanks alot anyways i appreciate ur help.
aaa
