Magnets for Eclipse Navi
gravedilute
Member - Posts: 6
Posted: September 20, 2006 at 2:09 AM / IP Logged
Has anyone successfully used a magnet kit for use with an Eclipse navi when you can't find the VSS?
The Eclipse navi needs a pulsing ground, so what brand can do that?
Or, is it possible to use a 12V pulsing type and use like a hex inverter or something to change it to ground?
doibuy
Copper - Posts: 177
Posted: October 07, 2006 at 11:12 PM / IP Logged
I was able to get one to work on an 06 Chrysler 300M, but tried to do one on an 06 Ford 500, and couldn't get it to work.  I used a Rostra magnet kit.  I was told that they have a better one, but is much more expensive.  What kind of car are you installing it on?  Many of the CAN-BUS vehicles have adaptors available for the VSS.
Mike M2
Platinum - Posts: 2,652
Posted: October 08, 2006 at 7:15 AM / IP Logged
We started installing the AVN50D in cars that have VSS issues instead of the AVN30D. The 50D will work without a VSS. It shows a check pulse error a few times to start with but it will go away and track normaly with all functions working...
Mike M2
Tech Manager
CS Dealer Services
Sunday, May 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
