2006 ford e150 wiring
Welcome Guest :)
romic00
Member -
Posted: October 01, 2006 at 11:23 AM / IP Logged
HI i am looking for a 2006 ford e150 van wiring diagram for a remote starter. If anyone can help i would appreciate it. Thank you
shaggy12volt
Copper -
Posted: October 01, 2006 at 11:44 AM / IP Logged
WIRING INFORMATION - FORD / ECONOLINE / 2006 / Remote Start| 12volts | lt. GREEN/ pur (x3)(common 60A) | + | ignition harness | | Starter | WHITE/ pink | + | ignition harness | | Second Starter | N/A | | | | Ignition | pink/lt. green | + | ignition harness | | Second Ignition | N/A | | | | Third Ignition | N/A | | | | Accessory | gray / YELLOW (x2) | + | ignition harness | | Second Accessory | BLACK/ lt. green | + | ignition harness | | Keysense | BLACK/ pink | - | ignition harness | | Power Lock | red to ORANGE / black | 5wi | either kick, door harness | | Notes: Use the passenger door lock switch when metering the wires, as it is the master switch.On vehicles with remote keyless entry, use pink / YELLOW (-) for lock and pink/lt. green (-) for unlock in either kick or at the VSM in the passenger kick. | | Power Unlock | brown to yellow/red | 5wi | either kick, door harness | | Notes: Use the passenger door lock switch when metering the wires, as it is the master switch.On vehicles with remote keyless entry, use pink / YELLOW (-) for lock and pink/lt. green (-) for unlock in either kick or at the VSM in the passenger kick. | | Lock Motor | pink/black | 5wi | VSM in passenger kick | | Unlock Motor | RED / orange | 5wi | VSM in passenger kick | | Parking Lights+ | brown | + | headlight switch or VSM | | Notes: Only vehicles equipped with remote keyless entry have the VSM. The VSM is in the passenger kick panel. | | Parking Lights- | N/A | | | | Hazards | same as turn signal wires | | | | Turn Signal(L) | lt grn/wht (F), lt grn/org (R) | + | turn signal switch | | Turn Signal(R) | wht/lt blu (F), org/lt blu (R) | + | turn signal switch | | Reverse Light | BLACK/ pink | + | driver kick, harness to rear | | Door Trigger | see notes | - | each pin switch or VSM | | Notes: The driver door trigger is RED / pink. The passenger door trigger is BLACK/ white. The sliding door trigger is white, if equipped. Vehicles that have the hinged side doors, the door triggers are common with the passenger door. Use all wires and diode isolate each.Only vehicles equipped with remote keyless entry have the VSM. The VSM is in the passenger kick panel. | | Dome Supervision | BLACK/ lt. blue | + | relay to right of steering column | | Trunk/Hatch Pin | common with pass. door trigger | | | | Hood Pin | N/A | | | | Trunk/Hatch Release | N/A | | | | Power Sliding Door | N/A | | | | Factory Alarm Arm | N/A | | | | Factory Alarm Disarm | N/A | | | | Disarm No Unlock | N/A | | | | Tachometer | WHITE/ pink | ac | PCM, top plug, pin 25 | | Notes: The PCM is under the hood, next to the brake master cylinder.On diesel vehicles, the tach wire is in the top plug, pin 1. | | Wait to start | see DirectFax document 1091 | | | | Brake Wire | dk. green | + | brake pedal switch | | Parking Brake | lt. GREEN/ red | - | parking brake switch | | Horn Trigger | dk. blue | - | horn switch or VSM | | Notes: Only vehicles equipped with remote keyless entry have the VSM. The VSM is in the passenger kick panel. | | Memory Seat 1 | N/A | | | | Memory Seat 2 | N/A | | | | Memory Seat 3 | N/A | | |
| Interface Module: | Category:Immobilizer Bypass | Required:No | Type: |
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
romic00
Member -
Posted: October 04, 2006 at 4:35 PM / IP Logged
Wednesday, April 1, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
