how to bridge an amp?
DYohn
Platinum - Posts: 10,741
Posted: October 09, 2006 at 11:19 AM / IP Logged
witzeln wrote:
how to bridge 1 X amp 2 channel?
Have you read your amplifier owner's manual?  What is the make/model of the amp?
DYohn
Posted: October 09, 2006 at 2:17 PM / IP Logged
A mono amplifier connection has only one "phase."  And, if you want to get technical, bridging a stereo amplifier does require one channel to be out of phase with the other.  Modern bridgeable amplifiers have an inverter module built-in.
trini ghost
Posted: October 09, 2006 at 3:51 PM / IP Logged
well i eh know how tuh explain it.....let me see....you know how a 2 channel amp will look like this>>>>>>>>>>>
(+)    -     +     ( - )           <---- those are the terminals
well yuh takin d ones i put in the brackets and using the posites wire from your subs....and puttin it in  ( + )  and use the negative wire from your subs and put it in ( - )......
(well at least that is how i do it usin soundstream amps.....i dont really have much experience with other brands....i'm kinda livin with dat brand a couple of years now....the only other brand amp i experienced other than soundstream is precision power (the old school ones....it was a 6 channel...lol....dats how old school it was) and my cousin uses plenty USAMPS....i never tried them though...as i said ...i only got access to use soundstream
trini ghost
Posted: October 09, 2006 at 3:53 PM / IP Logged
oh yes....and the term i couldn't have remembered was "out of phase"...as no use for a name said.....thanks....hahaha
DYohn
Posted: October 09, 2006 at 3:57 PM / IP Logged
Trini:  The proper speaker terminals to use for bridging a multi-channel amplifier can vary depending on the amplifier manufacturer, and not all amps are bridgeable.  Once a stereo amp has been bridged, it functions as a mono amp and there is only one phase.  Connecting multiple speakers to the single output is where it might be possible to have one speaker out of phase with the other.
trini ghost
Posted: October 09, 2006 at 4:23 PM / IP Logged
^^^^^^DYohn....your absolutely right......because that happened with two of my mid range speakers when i bridged my amp to play them....i have 2 10" 18sound in the back dash and 2 8" 18sound in the front doors....i got molds made for them...and one of the 10's was out of phase when i bridged the 2 channels to play them.....one was movin upwards and the other was moving downwards......you know exactly what i'm talkin bout..      how to bridge an amp? - Page 2 - Last Post -- posted image.
stevdart
Platinum - Posts: 5,816
Posted: October 11, 2006 at 9:37 PM / IP Logged
reverse polarity = 180 degrees change in phase
so...saying "out of phase" is correct.  If it's not in phase, it has to be out of phase.
