2003 Dodge Ram Remote turn on wire
Posted: October 06, 2006 at 11:02 PM / IP Logged
Hello,  Looking to install a few amps in my 2003 Dodge Ram.  I was needing to know which wire to use for my remote turn on.  I will be using the factory radio and just adding the amps.  Thanks
geepherder
Platinum - Posts: 3,668
Posted: October 06, 2006 at 11:50 PM / IP Logged
Just use a switched accessory wire. It'll read 12 volts with the meter when the key is in the accessory position. This wire should be green at the ignition harness.
