on button Window roll down
emperor
Posted: October 07, 2006 at 1:29 PM / IP Logged
            IS there or does anyone know how to wire it up so that when you press the window switch down once, it rolls window all way down. Or do i need a module or some other setup? i would be using this setup on a 3 wire 1960s window switch using dual relays(Actuators / Reverse Polarity setup) for a newer 5 wire pwr window setup. Thanks
master5
Silver - Posts: 1,123
Posted: October 10, 2006 at 4:28 AM / IP Logged
You have to use a module since a relay/timer setup is unsafe, although cheaper. I know all of the newer DEI window modules have the one touch feature built in and are not that expensive. They are also very simple to install with all circuit types and have switches which allow you set the current for the wiring type and system demands.
kreativesailor
Member - Posts: 28
Posted: October 22, 2006 at 11:13 AM / IP Logged
Here is a cheap way of doing your own One touch down window.
https://www.the12volt.com/installbay/forum_posts.asp?tid=74159&KW=One+Touch+down
Be advised you will have to use one module per window.
You can try and fail but dont fail to try...
bowez
Member - Posts: 11
Posted: November 05, 2006 at 4:47 PM / IP Logged
Noticed using the module form a Ford is there a part number to make get them easier?
master5
Posted: November 05, 2006 at 5:25 PM / IP Logged
Note on the ford module... that link is a way to make the passanger window one touch if you already have the driver. So basically you would need one of those mods for each window. If you request a part # you are probably considering getting it from ford.
Well even if only doing 2  windows those ford modules new are probably alot more expensive then using an aftermarket window module..which automatically do one touch on both windows..no need to rig anything..
If you can\t find those ford mods in a junk yard don't even bother with them. IMO not really a saving any money and may be more difficult to install. Plus if you get a used one you have to wonder why it's for sale if it works.
You never know with electronics from a junk yard, have had lots of bad experiences.
killer sonata
Silver - Posts: 718
Posted: November 05, 2006 at 6:26 PM / IP Logged
dei 530T one for each pair of windows
master5
Posted: November 05, 2006 at 10:10 PM / IP Logged
That'll do it Killer
bowez
Member - Posts: 11
Posted: November 06, 2006 at 5:42 PM / IP Logged
Reason I asked for the Ford pn is I may be able to source a cheap OEM source.
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
