2003 Cadillac CTS Alarm/Remote Start Wiring Guide
beck1234
Posted: October 12, 2006 at 10:19 AM / IP Logged
Can anyone help me out, im looking for a wiring guide for a remote start for a 2003 cadillac cts, Thanx
Mike Beck
josh1979
Silver - Posts: 320
Posted: October 12, 2006 at 10:52 PM / IP Logged
12volts RED / white (x2)(10A each) + ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense lt. green - pin B10, brown plug at DIM
Notes: The DIM (Dash Integration Module) is under the glove box.
Power Lock ORANGE / black - door lock switch in driver door
Notes: Can also use Directed 457GW interface module.
Power Unlock ORANGE / black - door lock switch in driver door
Lock Motor gray driver door module in door
Unlock Motor tan driver door module in door
Parking Lights+ DO NOT USE
Parking Lights- BROWN / white - pin B3, brown plug at DIM
Hazards lt. blue - pin A9, brown plug at DIM
Turn Signal(L) lt. blue/white + turn signal switch
Turn Signal(R) dk. blue/white + turn signal switch
Reverse Light lt. green + LR fuse box under rear seat
Door Trigger gray - underdash light
Notes: Individual door triggers are in each door at their respective door modules. The driver door trigger is tan, the RF door is lt. green, the LR door is dk. blue/white, and the RR door is yellow/black. Use all four wires and diode isolate each wire from each other and the door modules. Refer to DirectFax document 1076 for wiring information.
Dome Supervision comes on with disarm
Trunk/Hatch Pin gray or ORANGE / black - pin B3, red plug at RIM
Notes: The RIM (Rear Integration Module) is on the passenger side rear deck.
Hood Pin pnk/blk (export model only) - pin B1, brown plug at DIM
Trunk/Hatch Release lt. blue - pin B4, brown plug at RIM
Power Sliding Door N/A
Factory Alarm Arm yellow (export model only) - driver door module in door
Factory Alarm Disarm lt. green - driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white ac pin 35, connector 2 at ECM
Notes: The ECM (Engine Control Module) is on the passenger side of the motor under the cover. The tachometer wire can also be found at the instrument cluster.
Wait to start N/A
Brake Wire lt. blue/white + brake pedal switch
Parking Brake lt. blue - parking brake switch
Horn Trigger tan - pin A6, gray plug at DIM
Memory Seat 1 white - memory seat switch in door
Memory Seat 2 purple - memory seat switch in door
Memory Seat 3 N/A -
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PASS-Key III+
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Not required if using the combo interface module.
Combo Interface
Required:
Yes
Type:
Data Bus
Part #: 457GW
Notes:
bring back the rotary phone so i dont have to press 1 to proceed in english
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
