Alpine 3549 amp, 1.5 cubic foot box
jamesbond
Posted: October 16, 2006 at 10:35 PM / IP Logged
I need some advice. I have an Alpine 3549 300 Watt mono. I also have a 1.5 cubic foot box. I have 2 choices.
1. 1-Eclipse 10" DVC both 4ohm = 2 ohm load
or choice two
2. 2-Older MTX Road Thunder PRO's 8ohm each = 4 ohm load
What should I do? Run the 1 Eclipse in a 2 ohm config or the 2 MTX's in an isobaric & a 4 ohm config? The box was designed for the Eclipse but I have the other 2 just laying around and thought I might just use them. I know that the box design for a iso config is usually 1/2 the normal size. How would the box do at normal size? Thanks for any help.
James Bond 007
Universal Exports
Shane
stevdart
Platinum - Posts: 5,816
Posted: October 16, 2006 at 11:24 PM / IP Logged
Eclipse or Road Thunder?  Hmmm....
Alpine 3549 amp, 1.5 cubic foot box - Last Post -- posted image.
aznboi3644
Gold - Posts: 2,600
Posted: October 17, 2006 at 3:50 PM / IP Logged
haha...ROAD THUNDER BABY!!!!
forbidden
Platinum - Posts: 5,354
Posted: October 17, 2006 at 6:02 PM / IP Logged
Hold the bus, if that is the old 3549 mono amp, it was not stable to 2 ohm mono, back to the subwoofer drawing board you go.
forbidden
Posted: October 17, 2006 at 6:24 PM / IP Logged
Use the Eclipse and use one coil only on it.
geepherder
Platinum - Posts: 3,668
Posted: October 17, 2006 at 7:05 PM / IP Logged
It will be halved.
Flakman
Copper - Posts: 365
Posted: October 17, 2006 at 7:10 PM / IP Logged
geepherder wrote:
It will be halved.
I don't think that is correct geep...but I do not have the stats to back it up...so here's a grain of salt to go with it.Alpine 3549 amp, 1.5 cubic foot box - Last Post -- posted image.
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
jamesbond
Posted: October 17, 2006 at 9:36 PM / IP Logged
Thanks for the posts. I have ran the Eclpise for a couple of weeks @ 2 ohms and had no problem. The amp does get warm but no thermal shutdown. But out of these two choices which one will have the most "bang for my buck".
Shane
geepherder
Posted: October 18, 2006 at 5:28 AM / IP Logged
My mistake, that article is a good read.
