2000 Grand AM SE basic car
chuckles_1205
Member - Posts: 13
Posted: October 19, 2006 at 5:55 PM / IP Logged
My wife has a well 2000 Grand AM SE with no security features built in I am wondering since it doesn't have a security or remote start do I have to worry about the DEI 55L bypass Module, becuase I do not know if I have the GM passlock feature.
Thanks guys you all rock!!
kgerry
Platinum - Posts: 3,455
Posted: October 19, 2006 at 6:59 PM / IP Logged
you do have PL II.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
chuckles_1205
Member - Posts: 13
Posted: October 19, 2006 at 8:39 PM / IP Logged
So I do crap!
Link
I am assuming that I need something like this, then I could wire up everthing normal like the instructions say. Correct.
chuckles_1205
Member - Posts: 13
Posted: October 19, 2006 at 8:52 PM / IP Logged
Ok sorry this one better
I am assuming this is the right product vs the other link that I have showing.
Twelvoltz
Platinum - Posts: 2,384
Posted: October 19, 2006 at 9:25 PM / IP Logged
Neither of your links are working directly. To bypass the passlock systems, DEI's 556L has never let me down, but as of late I have been using the GMBP from bypasskit.com. The reason I prefer the GMBP is you do not have to cut any of the factory wiring to bypass the passlock, it achieves it via the databus.
chuckles_1205
Member - Posts: 13
Posted: October 19, 2006 at 10:28 PM / IP Logged
Likes try this again!
So this what I found just like you said.
Twelvoltz
Posted: October 19, 2006 at 11:43 PM / IP Logged
Link still not working. As long as it is the GMBP or equivalent it is right. DEI says you will need 2 relays and a 1.5K resistor to finish the job.
DIRECTWIRE™ WIRING INFORMATION - PONTIAC / GRAND AM / 2000 / Remote Start
[PRINT THIS PAGE]
12volts red    +   ignition harness
Notes: Remove the radio, without unplugging it, to access the ignition harness.
Starter yellow    +   ignition harness
Second Starter
Ignition pink    +   ignition harness
Second Ignition dk. green    +   ignition harness
Third Ignition
Accessory orange    +   ignition harness
Second Accessory brown    +   ignition harness
Keysense
Power Lock white    -   black plug in dkp
Notes: Lock requires a negative trigger, and unlock requires a negative trigger through a 1,500 ohm resistor. Must use relays. Must close doors to lock with a single pulse.
Power Unlock same wire
Lock Motor gray      drivers kick panel
Unlock Motor tan      drivers kick panel
Parking Lights+ brown      passenger kick or column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      -
Notes: The lt. GREEN/ black is located in the drivers kick and catches only the drivers door. The lt. blue is located in the harness coming from the drivers running board going under the drivers seat and it catches all other doors. Use both door trigger wires and diode isolate each. On the 2 door the lt.blue is in the passenger kick.
Dome Supervision white    -   dash light or column
Trunk/Hatch Pin ORANGE / black    -   trunk light
Hood Pin
Trunk/Hatch Release BLACK/ white   -   trunk release switch
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer white or PURPLE / wht      ignition coil or ECM
Notes: The ECM is located under the left side of the dash to the left of the column.
Wait to start
Brake Wire lt. blue    +   at the switch
Parking Brake
Horn Trigger black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:
Door Lock Interface Required:
Yes Type:
Multiplex
Part #: 456LW
Notes:
Combo Interface Required:
Yes Type:
Data Bus
Part #: 457GW
Notes: Can use the 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
Smart Starter Kill Relays: Not Available
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Hymer
Silver - Posts: 695
Posted: October 19, 2006 at 11:58 PM / IP Logged
If your not doing a remote start you dont need to worry about it....
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
chuckles_1205
Member - Posts: 13
Posted: October 20, 2006 at 6:53 AM / IP Logged
Ok well I just a order GMBP from ebay so that is good I have to order the alarm and remote start now, then I can start wiring this beast up now.
Thank you much guys!
Saturday, June 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
