VSS cable color on 97 Lincoln
anwarshah
Posted: November 03, 2006 at 4:02 PM / IP Logged
Can anyone help me with the location and the color of the VSS cable on a 1997 Lincoln Towncar?
Many thanks...
sabir
KarTuneMan
Platinum - Posts: 7,056
Posted: November 18, 2006 at 10:12 PM / IP Logged
REVERSE LIGHTS BLACK/ pink In driver's kickpanel   +
 DIMMER ORANGE / black At any illuminated dash switch
 VSS WIRE Gray/black At module in left rear of engine compartment
 TRANSPONDER IGNITION RED / lt.green 4 pin connector ( near steering column)   +
 TRANSPONDER DATA 1 Gray/orange 4 pin connector ( near steering column)   DATA
 TRANSPONDER DATA 2 WHITE/ lt.green 4 pin connector ( near steering column)   DATA
 TRANSPONDER GROUND Pink/orange 4 pin connector ( near steering column)   -
