01 Ford Explorer Sport Trac
altbs
Member - Posts: 21
Posted: November 10, 2006 at 8:27 PM / IP Logged
Need to put remote start in a 2001 Ford Explorer SportTrac if anyone has a wiring diagram I would appreciate it.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 14, 2006 at 5:10 PM / IP Logged
Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS Yellow Ignition switch harness   +
 IGNITION Lt.GREEN/ violet Ignition switch harness   +
 IGNITION 2 BLACK/ green Ignition switch harness   +
 ACCESSORY Brown Ignition switch harness   +
 STARTER Red & RED / blue Ignition switch harness   +
 KEY SENSE BLACK/ pink Ignition switch harness   -
 Wire goes to pin 10 (early production) or pin A-18 (late production) of GEM behind center of dash.
 TACH SIGNAL See notes At coil pack on engine   AC
 This is a multi-coil engine. On the 4L the wire is TAN/WHITE and on the 5L it is RED / BLUE. Set your remote starter for 2 cylinders.
 LOCK Pink / YELLOW In driver's kickpanel   -
 The locks stop working 20 seconds after the doors are locked. To unlock the doors, you must pulse the disarm wire (GREEN/ VIOLET) at the same time as unlock. For models equipped with no keyless entry or security, the doorlock are reverse polarity.
 UNLOCK Pink/green In driver's kickpanel   -
 DRIVER LOCK MOTOR Pink/black In driver's kickpanel   +
 DRIVER UNLOCK MOTOR RED / orange In driver's kickpanel   +
 PASSENGER UNLOCK MOTOR Pink/orange In passenger side kickpanel   +
 DOORPIN BLACK/ blue In driver's kickpanel   +
 FACTORY DISARM GREEN/ purple In driver's kickpanel   -
 BRAKESWITCH RED / green At switch above brake pedal   +
 PARKLIGHTS Brown At steering column   +
 HORN YELLOW /GREEN At steering column   -
 HEADLIGHTS RED / yellow At steering column   +
 VSS WIRE Gray/black Behind instrument panel   AC
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
