2000 Malibu R/S problem
start25
Copper - Posts: 114
Posted: November 13, 2006 at 11:36 PM / IP Logged
About 2 weeks ago I installed Crimestoper Remote Start, with PLJX bypass unit and everything worked fine untill today, remote doesnt lock or unlock or start the vihicle, only get blinking lights.  Has this happened to anybody before?  What could be the problem?
qdaddy
Copper - Posts: 133
Posted: November 14, 2006 at 2:06 AM / IP Logged
power and ground module separetly  check all conex then relearn2000 Malibu R/S problem - Last Post -- posted image.
start25
Copper - Posts: 114
Posted: November 14, 2006 at 10:10 AM / IP Logged
What module?  The bypass module?
ziggyb222
Silver - Posts: 593
Posted: November 14, 2006 at 10:15 AM / IP Logged
Do you get a security light flashing when you try to remote start it? It should try to start.. How was the starter installed?/ Soldered???
start25
Copper - Posts: 114
Posted: November 14, 2006 at 10:20 AM / IP Logged
No security light flashing, was not soldered...Do you have to solder all connections?
ziggyb222
Silver - Posts: 593
Posted: November 14, 2006 at 10:38 AM / IP Logged
No you dont have to solder your connection, But I think it ensures a good solid connection. You need to check the connection from your brown wire on the remote and make sure it is not loose. Seems like the unit is getting the signal to start, but the voltage is not getting to the starter wire in the car....
