vss location for dodge ram 2004 hemi
dodgenav
Posted: November 28, 2006 at 10:44 AM / IP Logged
i am installing the pioneer avic-n3 and am having trouble with the locator.  it seems to be because of the speed sensor.  i have a 2004 dodge ram 1500 with the 5.7 hemi.  can someone tell me where to locate the vss and hook it up? i have seen other posts that give some information, but not for specifically my truck.
thanks for the help.
Mike M2
Platinum - Posts: 2,652
Posted: November 28, 2006 at 5:06 PM / IP Logged
Speed Sense dk. GREEN/ YELLOW    PCM, top black plug, pin 13
Notes: The PCM is on the passenger side firewall.
On diesel models, the vss wire is at the ECM on the lower driver side of the engine, 50 pin plug, pin 11.
Mike M2
Tech Manager
CS Dealer Services
dodgenav
Posted: November 28, 2006 at 9:17 PM / IP Logged
thanks.  does it matter if i have an automatic or manual transmission?  I have an automatic.
dodgenav
Posted: November 28, 2006 at 9:30 PM / IP Logged
one more thing.  is there anyway that i can test that that is the correct wire before i cut into it?  I don't want to screw up my truck.
dstang24
Copper - Posts: 98
Posted: November 28, 2006 at 10:11 PM / IP Logged
Posted: January 07, 2006 at 4:55 PM - IP Logged
vss location for dodge ram 2004 hemi - Last Post -- posted image.
This is my 2004 Dodge Ram 1500 AT... I installed the N2 recently.  Both the VSS and the Reverse wire are by the PCM, which, yes is in the engine compartment.  I have a picture of the install.  The wire on the right is the VSS wire (solder & tape) while the one on the left (in the t-tap, got lazy) is the reverse wire, which is only hot when the vehicle in RUNNING and in reverse.  Again, the engine must be turned over to make this wire go hot.
REVERSE : White w/ light green BY (next to) the PCM       -- it was on the front bumper side of the plug that's on the fender there...
VSS:  Dark Green w/ Yellow    IN (connected to) the PCM
Reminder... This is my '04 and it's a 1500... It seems to be similar to yours so you might use it as a guide.
Hope this helps!
-Dstang24
...This is a forum discussion from earlier this year... These are the wires you are looking for
Team Edge Audio
dodgenav
Posted: November 29, 2006 at 2:31 PM / IP Logged
Thank you guys for the help
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
