2006 Nissan Altima alarm wiring
pitoaudiovisual
Copper - Posts: 388
Posted: November 28, 2006 at 2:49 PM / IP Logged
Can anyone please give me the wiring diagram for a 2006 Nissan Altima and also if the car needs a bypass.  Thanx in advance.
Confidence is the key to any project!!
Mike M2
Platinum - Posts: 2,652
Posted: November 28, 2006 at 5:12 PM / IP Logged
12voltsgreen (40A) + ignition harness
StarterBLACK/ red + ignition harness
Second StarterBLACK / YELLOW + ignition harness
IgnitionBLACK/ red + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessoryred + ignition harness
Second AccessoryWHITE/ blue + ignition harness
KeysenseBLACK/ red + ignition harness or BCM, pin 37
Power Lockbrown - BCM to right of fuse box, pin 45
Notes: These wires are only available on vehicles with left front only power window anti-pinch system. On vehicles with left AND right front power window anti-pinch system, use the factory alarm arm and disarm wires for door locks.
Power Unlockpink - BCM to right of fuse box, pin 46
Lock Motoryellow/red 5wi BCM to right of fuse box, pin 65
Unlock MotorGREEN / WHITE 5wi BCM to right of fuse box, pin 59
Parking Lights+RED / blue + driver kick, harness to rear
Parking Lights-N/A
HazardsGREEN/ red - BCM to right of fuse box, pin 29
Turn Signal(L)GREEN/ black + BCM to right of fuse box, pin 60
Turn Signal(R)GREEN/ YELLOW + BCM to right of fuse box, pin 61
Reverse LightGREEN / WHITE + driver kick, harness to rear
Door Triggersee notes - BCM to right of fuse box
Notes: The LF door is lt. blue in pin 47, RF door is pink/blue in pin 12, LR door is RED / black in pin 48, and RR door is RED / white in pin 13. Use all four wires and diode isolate each.
Dome Supervisionred - BCM to right of fuse box, pin 63
Trunk/Hatch PinPURPLE / white - BCM to right of fuse box, pin 42
Hood PinN/A
Trunk/Hatch ReleaseRED / black or blue/red - BCM to right of fuse box, pin 30
Power Sliding DoorN/A
Factory Alarm Armpink/blue - driver door module in door, pin 4
Notes: Meter this wire while turning the key in the driver door key cylinder.
This wire will also lock the doors.
On vehicles with left front only power window anti-pinch system, this wire is found at the BCM to the right of the fuse box, pin 8.
Factory Alarm DisarmWHITE/ blue - driver door module in door, pin 5
Single pulse on this wire will disarm the factory alarm, and double pulse will unlock the doors.
On vehicles with left front only power window anti-pinch system, this wire is found at the BCM to the right of the fuse box, pin 7.
Disarm No Unlocksee factory alarm disarm
TachometerNOT red, pink, or black ac any ignition coil or fuel injector
Wait to startN/A
Brake WireRED / green + brake pedal switch
Parking Brakegreen - parking brake switch
Horn TriggerGREEN / WHITE - horn switch
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
2006 Nissan Altima alarm wiring - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Mike M2
Tech Manager
CS Dealer Services
mrfikzit65
Posted: January 13, 2007 at 2:45 PM / IP Logged
mike thanks a whole lot for this info i'll let you know how i make out
Monday, June 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
